Determine is box of unknown mass is sliding down a ramp?
The problem involves a box of unknown mass resting on a ramp inclined at an angle of 16 degrees. The coefficients of static and kinetic friction are provided, and the question is whether the box will slide down the ramp upon release. The discussion centers around the forces acting on the box and the conditions for motion.
  • Participants discuss the balance of forces acting on the box, particularly the weight component along the ramp and the frictional forces. There are attempts to analyze the conditions under which the box would start sliding, including calculations involving the coefficients of friction.
Several participants have offered insights into the forces at play, questioning the assumptions made about static friction and the conditions for motion. There is an ongoing exploration of how to properly apply Newton's second law in this context, with no clear consensus reached yet.
Participants note the importance of the angle of the ramp and the relationship between the gravitational force and frictional force in determining whether the box will slide. The discussion reflects uncertainty regarding the correct application of forces and the implications of the given coefficients of friction.
Jojo96
A box of textbooks at unknown mass rests on a loading ramp that makes an angle α = 16o with the horizontal. The coefficient of static friction is 0.30, and kinetic friction is 0.25. Then the box is released. (a) Will it start sliding down the ramp? (a) Find the normal force on the box (b) If it slides down then find the acceleration of the box
2. Relevant
F=ma
ƒ=µn
Forces in x-direction:
w-ƒstatic=0
w=ƒstatic
mgsin(16)=µn
y: n-w=0
n=w
n=mgcos(16)
mgsin(16)=µmgcos(16)
sin(16)=µcos(16)
sin(16)/cos(16)=µ
But already know µ so this doesn't help me...
[/B]
By assuming ##\sum F_x=0## you're stating that the block isn't moving in the x direction. Try using ##\sum F_x=ma_x##
Jojo96 said:
3. The Attempt at a Solution
w-ƒstatic=0
w=ƒstatic
mgsin(16)=µn
y: n-w=0
n=w
n=mgcos(16)
sin(16)=µcos(16)
sin(16)/cos(16)=µ
with the ramp at your angle theta - if you calculate the force driving the box then perhaps it will come out less than the frictional force opposing the tendency to slide down- as it will be mu. M.g .cos (angle)
The only force that is driving it down is the weight. Nothing is pulling the box. Also, what would I use for acceleration in the x direction for F=ma?
Component of weight along the slope is pulling the box down. Check if it is sufficient to overcome static friction.
along the ramp the force acting downward will be component of Mg - i.e. Mg sin(16)- but your body can not move with this pull along the ramp as frictional force is larger - if you increase the angle of ramp then only it can move at an angle Theta such that Mgsin(theta) exceeds
(Coeff. of friction XMg Cos(theta)) which is opposing the motion acting along the ramp in upward direction.
