Shunt Resistance Calculation for a DC Circuit with 2 Parallel Resistors
In summary, you are trying to find the required shunt resistance if the maximum current flowing through the circuit is 200A. The meter can read a maximum of 1 mA and has a resistance of 0.1Ω. You can use the product over sum rule to get the potential across the shunt resistance. If you use the current divider rule, you would get 10^(-6)/199.9=0.0001/200A=0.5 microohm.
damon669
33
DC circuit
2 resistors in parallel Rm and Rs
one resitance will be a meter (Rm =0.1 ohm), the other will be the shunt
Max current is 200A
Im (meter current is 1mA)
I= Is + Im
V=IRt
I am thinking first to find shunt current which Is
Is = I - Im
=199.9A ?
damon669 said:
DC circuit
Max current is 200A
I= Is + Im
V=IRt
Is = I - Im
=199.9A ?
Hi damon669, Welcome to Physics Forums.
Yes, the shunt current will likely come in handy. What is it you're trying to find? Your problem description doesn't explicitly pose a question...
The question is
Determine the required value of the shunt resistance if the maximum value of the current I is 200A. The meter can read a maximum of 1 mA and has a resistance of 0.1Ω
damon669 said:
The question is
Okay. So you know the currents that are flowing through each of the components (you might want to hang on to a few more decimal places for the shunt current for intermediate steps, since you are dealing with a difference between a large number and a tiny one). What else can you determine from the given values?
V=IR
so 0.1 x 0.00001
= 0.0000001
damon669 said:
V=IR
so 0.1 x 0.00001
= 0.0000001
Yes, you can determine the potential across the meter resistance. However, be careful of your decimal places... check the value you've used for current. (it's often advantageous to use scientific notation, particularly when metric prefixes are given). Also be sure to include units on results.
So then, what's the potential across the shunt resistance?
Rs = V/Is
10^(-6)/199.9
I read you can use product over sum rule to get V
V=I x RsRm/Rs+Rm
can I use this? if so how to make Rs the subject?
5mV?
damon669 said:
Rs = V/Is
10^(-6)/199.9
Your result will be out by a few orders of magnitude. Did you check the current value that you used for I am as I suggested?
V=I x RsRm/Rs+Rm
You could do that. It's just algebra, rearranging the expression. Start by getting rid of the fraction (multiply both sides by the denominator expression).
There's a more straightforward option, too. Look up "current divider". It would go well with the starting values you've been given.
damon669 said:
5mV?
What is that supposed to be?
current divider gives
I = I am + Is
so Is = I - I am (already done)
I - V/Rm
thought i worked out the voltage to be 5mA, which would be the same in all parts of this parallel circuit
I = I am + Is
I - V/Rm
That doesn't look like the current divider rule, and you're not given V ahead of time...
But before going on with a new method you need to fix the one you've used first. Check the numerical value you've used for Im!
While it is true that the voltage will be the same across both resistances, that voltage is not 5mV !
(and mA is a current: milli-Amps).
Redo your voltage calculation and pay particular attention to the magnitudes of the values!
V = IR
= 0.001 x 0.1
=0.0001
= 10^(-4)
damon669 said:
V = IR
= 0.001 x 0.1
=0.0001
= 10^(-4)
That looks better :smile: Be sure to add units to your results! Always! You will lose marks if you fail to include units!
So, with an appropriate metric prefix that would be 0.1 mV.
So Rs = V/Is
=0.0001/199.9
=0.0000005003 ohms
damon669 said:
So Rs = V/Is
=0.0001/199.9
=0.0000005003 ohms
Yup. Now's the time to use scientific notation and round results to the appropriate number of significant figures.
0.5003 microhms
and that's it
must admit did not expect an microohm answer
damon669 said:
0.5003 microhms
Too many significant figures... take a look at the original given values to determine how many significant figures are appropriate. Otherwise it looks good.
0.5 microohm
damon669 said:
0.5 microohm
Looks good! :approve:
Likes 1 person
1. What is shunt resistance and why is it important?
Shunt resistance is a measure of the resistance in a parallel circuit. It is important because it affects the overall current flow in the circuit and can also impact the accuracy of measurements in the circuit.
2. How do you determine the shunt resistance in a circuit?
The shunt resistance can be determined by using Ohm's law, which states that the resistance is equal to the voltage divided by the current. By measuring the voltage and current in the parallel circuit, the shunt resistance can be calculated.
3. What factors can affect the shunt resistance?
The material and thickness of the shunt resistor, as well as the temperature and current flowing through it, can all impact the shunt resistance. Additionally, any changes in the surrounding environment or connections in the circuit can also affect the shunt resistance.
4. How does shunt resistance impact the accuracy of measurements in a circuit?
Shunt resistance can introduce errors in the measurement of current in a circuit. This is because it creates a parallel path for current flow, which can affect the overall current in the circuit and lead to inaccurate measurements.
5. Can shunt resistance be adjusted or controlled?
Yes, shunt resistance can be adjusted by changing the material or thickness of the shunt resistor. It can also be controlled by using a variable shunt resistor or by adjusting the current flow in the circuit.
12K
