Determine work done by electric field
The discussion focuses on calculating the electric potential difference, V_MN, between two points M(2,6,-1) and N(-3,-3,2) in a given electric field. The user initially attempts to find V_MN by normalizing the displacement vector, which leads to an incorrect result of -103.97 V, while the textbook solution is -139.0 V. The correct approach involves using the full displacement vector without normalization, expressed as dℓ = i dx + j dy + k dz. The error stems from the incorrect application of the displacement vector in the integral calculation. Properly applying the displacement vector will yield the correct potential difference.
Baramos
Given electric field ##\vec E = 6x^2\hat i +6y\hat j+4\hat z## v/m
Find ## V_{MN}## if both M and N separate by M(2,6,-1) and N(-3,-3,2)
here i find ##V_{MN}## by
unit vector from N to M is ##\frac 1 {\sqrt (115)}(5\hat i +9\hat j -3\hat k)##
so ##V_{MN} = -\int \vec E \cdot \vec {dl} = \int \vec E \cdot \vec {\frac 1 {\sqrt 115}(5dx\hat i +9dy\hat j -3dz\hat k)}##
and then i find intregral with respect to x from -3 to 2
respect to y from -3 to 6
respect to z from 2 to -1
and my answer is -103.97 v but textbook solution is -139.0 v what i do wrong
You should not normalise ##d\vec \ell##. You need to use the appropriate expression for the displacement vector, i.e., ##d\vec \ell = \hat i dx + \hat j dy + \hat k dz##.
Likes orientor and Baramos
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
