Determining node voltage using Mesh Analysis and Thevenin's Theorem
The discussion revolves around using mesh analysis and Thevenin's theorem to determine the currents in a circuit and the voltages at specific nodes (A and B) with respect to a ground node. The context is primarily homework-related, focusing on circuit analysis techniques.
  • Homework-related, Technical explanation
  • The original poster expresses uncertainty about the method for determining the voltages at nodes A and B using the currents obtained from mesh analysis.
  • Some participants suggest finding the Thevenin equivalent current for the circuit and applying Kirchhoff's Voltage Law (KVL) to determine the node voltages.
  • One participant notes the importance of setting a current flow direction and adjusting the current values accordingly when applying KVL.
  • A later reply indicates that the original poster was able to resolve their issues independently, despite not fully understanding the guidance provided earlier.
Participants generally agree on the steps to take for solving the problem, but the original poster expresses uncertainty about their understanding and application of the methods discussed. The discussion does not reach a consensus on the best approach to determine the node voltages.
The original poster's uncertainties highlight potential limitations in their understanding of applying mesh analysis and Thevenin's theorem, as well as the need for clarification on the verification of node voltages.
zeroktrian
Using mesh analysis work out the currents flow through each of the three meshes. From these current values calculate the voltage of node A, and node B with respect to the ground node.
Find equivalents of sub circuits A-G, B-G, A-B by applying Thevenin's theory. Then place these equivalents together and prove that the voltage at node A, and node B will be the same as in the previous problem.
Kirchhoff's Current and Voltage Laws, Thevenin's laws.
My attempt at the solution should be visible in the images I uploaded. The three current values I obtained through Mesh Analysis have been verified using the Circuit Wizard program. My only uncertainties are with regards to determining the voltages at node A and B with respect to the ground node.
I am not certain whether my method for their determination using the currents from the Mesh Analysis are correct. Also, with their verification using Thevenin's theorem, I am not certain about how exactly to figure out the node voltages using the theorem.
If anyone could guide me in the right direction I would be most appreciative.
Thanks.
hey dude, I am also doing 103. What you need to do is find the thevenin equivalent current for ur Thevenin circuit. After you've done that, set a current flow direction i.e clockwise. To find V(a) and V(b) you then need to do KVL until u get to nodes A or B. Note that if you go against the current direction, your current value will have to be a negative. Hope i helped and hope its not too late. Good Luck.
Same here doing 103, got problem 5 though. Just follow acurabot's steps there correct. GL
Thanks for that Acurabot. I realize it is a ridiculously late post, but I thought I should thank you for the time you took to post. I ended up figuring it out (must admit I didn't get your post before I submitted), but thanks again.
