Development of 2nd Law Of Thermodynamics
The discussion revolves around the development and understanding of the Second Law of Thermodynamics, particularly its qualitative and quantitative aspects. The original qualitative postulates, such as the Kelvin-Planck and Clausius statements, are contrasted with the later quantitative formulations, including the efficiency of the Carnot cycle. The thread raises a critical question about the experimental validation of the Second Law, specifically whether there was a rigorous demonstration of its efficiency equation, eff = 1 - TL/TH, akin to Joule's demonstration of the First Law. Participants note that while Carnot made early measurements, the lack of precise experimental methods in the 19th century limited rigorous validation of the Second Law. The conversation highlights the evolution of thermodynamic principles and the ongoing exploration of their foundational experiments.
wcg1989
I am new here and have always loved the history of science as much as the science itself. I have been intrigued by the 2nd law of thermodynamics and entropy for a long time but have also had something about its evolution that bothered me. So I'll summarize its stated development from my thermodynamics book and then ask my question.
The relevant chapters cover it this way. First, they describe it as a set of qualitative postulates. Such as Kelvin-Planck which says roughly a device cannot be constructed that raises a weight and exchanges heat with only one reservoir. Or 2nd, the Clausius statement that says a device cannot be made that has no effect other than the transfer of heat from a cold to hot body. And finally, its impossible to construct a perpetual motion machine.
Now the book describes the concept of a reversible process and factors like friction or heat transfer through a finite difference that make a process irreversible. Then it discusses a reversible Carnot cycle and proposes that a reversible engine is the most efficient.
So far all qualitative.
Then finally quantitative. The chapter states that the efficiency of the Carnot cycle is only dependent on temperature.
eff = W/QH = (QH - QL) / QH = 1 - QL/QH = f(TH, TL)
and finally says that Lord Kelvin proposed this relationship for the development of a temperature scale in a reversible process.
QH/QL = TH/TL which also equates for a Carnot cycle that eff = 1 -QL/QH = 1-TL/TH
This can be re-written as QH/TH - QL/TL = 0 and finally that is generalized as the Clausius integral where
Integral (dQ/T) = 0 for a reversible engine. And since for an irreversible engine, QLirr > QLrev, then for an irreversible engine,
Integral (dQ/T) < 0
And that is the 2nd law of thermodynamics stated in a quantitative way. Now here is the problem I have.
With the 1st law of thermodynamics, Joule demonstrated it by using a paddle wheel in a container of water and showing that a falling weight connected to the paddle would heat the container by a quantifiable amount. That demonstrated the 1st law. delta U = Q - W
Isaac Newton had developed the theory of gravity with F = GMm/d^2 and that was demonstrated because that equation can be used to derive the elliptical orbits of the planets that Kepler had described from observations a few decades earlier.
What experiment showed the 2nd Law specifically that the best efficiency of an engine was eff = 1 - TL/TH?
The equation eff = W/QH is a definition and the 1st law can be used to show that that is equivilant of eff = (QH-QL)/QH = 1-QL/QH but once that is transformed into efficiency of a reversible engine, eff = 1 - TL/TH, that is a declaration of the 2nd law.
Was it believed because it was elegant? Was there an experiment that really showed it, or as I suspect, it wasn't rigorously demonstrated because there was no good way of building a device that matched a Carnot reversible cycle at the time? It could in the 19th century, only generally be shown that as TL/TH decreased for a real engine, the efficiency got better.
I know that this is classical 2nd Law developed in the 1st half of the 19th century and that later a statistical concept of the 2nd law was formulated from which Integral (dQ/T) could be derived. But BEFORE that occurred, was the 2nd law demonstrated by experiment?
Thanks.
Science news on Phys.org
You are asking good questions! Your book appears to be a very typical undergraduate textbook and unfortunately it is quite incomplete.
If you can find it, Truesdell’s “The Tragicomical History of Thermodynamics, 1822-1854 (Studies in the History of Mathematics and Physical Sciences)”, is the gold-standard reference for this material. My copy is well-worn.
First, I want to focus on this:
“The relevant chapters cover it this way. First, they describe it as a set of qualitative postulates. Such as Kelvin-Planck which says roughly a device cannot be constructed that raises a weight and exchanges heat with only one reservoir. Or 2nd, the Clausius statement that says a device cannot be made that has no effect other than the transfer of heat from a cold to hot body. And finally, its impossible to construct a perpetual motion machine.
Now the book describes the concept of a reversible process and factors like friction or heat transfer through a finite difference that make a process irreversible. Then it discusses a reversible Carnot cycle and proposes that a reversible engine is the most efficient.”
Rather than give a detailed recount of the original publications from Clausius, Fourier, Reech, Duhamel, Carnot, Laplace, Kelvin, etc., let’s focus on the supposed ‘qualitative’ aspect of the body of work.
It is perhaps surprising that the first papers on heat and work had such rudimentary mathematics, but in point of fact, the paper by Carnot (in particular, but there are others) is atrocious.
This is a crucial point of fact as well: even though the original mathematical results had no rigorous foundation, the physical concepts the authors were attempting to describe mathematically are the correct concepts. That is, even though the formulas are a hideous conflagration of \delta , \Delta, d and ill-defined integrals, it is a fact (for example) that the rate of change of the internal energy of a system is the sum of the work(ing) and heat(ing).
But now we are left with all these ill-defined (in the quantitative sense) qualities like ‘energy’, ‘entropy’, ‘heat’, ‘temperature’… and this led to the next round of development: Kelvin, mostly. Kelvin corrects the mathematics and in so doing, invents the absolute temperature scale. An unfortunate side effect is that Kelvin turned thermodynamics into thermo*statics*. Every formula you presented is not a result of thermodynamics, but of thermostatics. The concepts ‘reversible’ and ‘equilibrium’ and ‘static’ are the same, and all expressed mathematically the same way.
Your book likely ends here, with this:
“I know that this is classical 2nd Law developed in the 1st half of the 19th century and that later a statistical concept of the 2nd law was formulated from which Integral (dQ/T) could be derived.”
This is unfortunate, because there is quite a bit more to the story. In brief, the study of thermodynamics was revived in the 1950s-1960s (along with continuum mechanics) and the fundamental axioms of thermo*dynamics* (note; 4 paragraphs above I wrote the 1st law in dynamical terms, not the usual E = W + Q thermostatic definition) were put on much more secure mathematical footing. Papers by Coleman (http://www.mechanics.rutgers.edu/BDC.html ) and others gave us mathematically rigorous definitions of thermodynamic variables.
What’s the point, since the 2nd law can be derived by statistical mechanics?
That sentence above reflects a fundamental misunderstanding of both statistical mechanics and thermodynamics. The arguments used to compute the entropy from axioms of statistical mechanics only hold for thermo*statics*. One essential difference between the laws of thermostatics and the laws of thermodynamics is the presence (or absence) of time. The 2nd law of thermodynamics has not been shown to be derivable from statistical methods. AFAIK, time appears nowhere in statistical mechanics, except for a single special case
Thermodynamics and continuum mechanics are correct physical models that encompass more of the universe than any other model, and many physicists have not heard of either.
How’s that? I can step you through details, but I need my books in front of me….
That was interesting thanks. I have seen some discussions of the differences between thermostatics and thermodynamics. I have also seen a discussion on deriving the thermostatic definition from statistics, but although I get the idea, I have not rigorously grasped it.
However, I am an engineer mostly involved in testing so that is how this thread sort of came up. I have seen little in the way of someone demonstrating the classical 2nd law with a test at least one from the time period that these classical thermostatic equations were first published.
Perhaps there were no tests in the 19th century on the 2nd law, or that they were just not rigorous? I mean Joule's test on the 1st law with the weight and paddle is simplicity itself, almost seems trivial now but I know at the time it was a big deal. But how does one demonstrate the 2nd law in that time period? All I can think of is that they could show that a real engine had a greater efficiency the larger the temperature difference. But they couldn't show it rigorously or precisely because those engines were far from "reversible".
Anyway thanks for the response.
The book I mentioned steps through Carnot's paper (the 2nd law). Carnot was an engineer, and he did in fact do a measurement (I'm not sure I'd call it an 'experiment'). As I said, I need the book in front of me, and it's in my office. I can provide a description on Monday.
I look forward to it. Thanks.
Edited to add:. Andy, when you are talking about the formulation of the 2nd law in terms of thermodynamics is this what you are referring to below? I copied this from Wikipedia and is a formulation of the rate of change of entropy in an open system with flow. Seems like a "dynamic" equation.
http://en.wikipedia.org/wiki/Entropy
dS/dt = mdot * Sin - mdot * Sout + Qdot /T + Sdotgen
Ok… now that I have my book, I can step through the various papers needed to establish the experimental basis of the second law. I want to say I’m glad to have to opportunity to work through this material in detail; I haven’t done this in a long time.
I figured we would start with Carnot’s (“REFLECTIONS ON THE MOTIVE POWER OF HEAT”, 1824) since it contains the very first statement of the second law. In the interest of scholarship, I’ll first write down exactly what is in the paper, and then ‘translate’ it as needed. Two things: first, remember I said the paper is atrociously written. Not incorrect, but a horrible mix of brilliant physical insight and grade-school mathematics. Second, most of what I have is written straight out of Truesdell’s book. I found an online copy of the translated original paper here: http://www.history.rochester.edu/steam/carnot/1943/
Again, I need to point out that his paper was written prior to notions of equilibrium and absolute temperatures.
First, the punchline: the data he used.
“According to the experiments of MM. Delaroche and Berard on the specific heat of gases, that of air is, for equal weights, 0.267 that of water. If, then, we take for the unit of heat the quantity necessary to raise 1 kilogram of water 1 degree; that which will be required to raise 1 kilogram of air 1 degree would have for its value 0.267. Thus the quantity of heat furnished by the body A is 0.267 units.
This is the heat capable of producing 0.000000372 units of motive power by its fall from 00.001 to zero.
For a fall a thousand times greater, for a fall of one degree, the motive power will be very nearly a thousand times the former, or 0.000372.
If, now, instead of 0.267 units of heat we employ 1000 units, the motive power produced will be expressed by the proportion 0.267/0.000372 = 1000/x , whence x = 372/267 = 1,395.
Thus 1000 units of heat passing from a body maintained at the temperature of 1 degree to another body maintained at zero would produce, in acting upon the air, 1.395 units of motive power.
Suppose the temperature of the body A 100 degrees, and that of the body B 99 degrees: the difference of the tensions will be, according to the table of M. Dalton, 26 millimetres of mercury or Om.36 head of' water.
The volume of the vapor is 1700 times that of the water. If we operate on one kilogram, that will be 1700 litres, or lme.700. Thus the value of the motive power developed is the product 1.700 x 0.36 = 0.611 units, of the kind of which we have previously made use.
The quantity of heat employed is the quantity required to turn into vapor water already heated to 1000. This quantity is found by experiment. We have found it equal to 5500, or, to speak more exactly, to 550 of our units of heat.
Thus 0.611 units of motive power result from the employment of 550 units of heat. The quantity of motive power resulting from 1000 units of beat will be given by the proportion 550/0.611 = 1000/x, whence x = 611/550 = 1.112.
Thus 1000 units of heat transported from one body kept at 100 degrees to another kept at 99 degrees will produce, acting upon vapor of water, 1.112 units of motive power.
Finally, we will show how far we are from having realized, by any means at present known, all the motive power of combustibles.
One kilogram of carbon burnt in the calorimeter furnishes a quantity of heat capable of raising one degree Centigrade about 7000 kilograms of water, that is, it furnishes 7000 units of heat according to the definition of these units given on page 88.
The greatest fall of caloric attainable is measured by the difference between the temperature produced by combustion and that of the refrigerant bodies. It is difficult to perceive any other limits to the temperature of combustion than those in which the combination between oxygen and the combustible may take place. Let us assume, however, that 10000 may be this limit, and we shall certainly be below the truth. As to the temperature of the refrigerant, let us suppose it .00 We estimated approximately (page 91) the quantity of motive power that 1000 units of heat develop between 1000and 990. We found it to be 1.112 units of power, each equal to 1 metre of water raised to a height of 1 metre.
If the motive power were proportional to the fall of caloric, if it were the same for each thermometric degree, nothing would be easier than to estimate it from 10000 to 00. Its value would be
1.112 x 1000 = 1112.
But as this law is only approximate, and as possibly it deviates much from the truth at high temperatures, we can only make a very rough estimate. We will suppose the number 1112 reduced one-half, that is, to 560. Since a kilogram of carbon produces 7000 units of heat, and since the number 560 is relatively 1000 units, it must be multiplied by 7, which gives
7 x 560 = 3920.”
Ok, to summarize so far:
1) 1000 units of heat passing from a body maintained at temperature of 1 degree to another maintained at 0 degrees would produce 1.395 units of work.
2) 1000 units of heat passing from a body maintained at the temperature of 100 degrees to another maintained at 99 degrees would produce, acting on steam, 1.112 units of work.
3) The motive power of burning 1 kg coal is 3920 units.
Recall, Carnot’s goal was to develop a more efficient steam engine, and he attempts to make his theory as general as possible. How does the data above lead the the second law of thermodynamics? Now we have the brilliant physical insight:
“According to established principles at the present time, we can compare with sufficient accuracy the motive power of heat to that of a waterfall. Each has a maximum that we cannot exceed, whatever may be, on the one hand, the machine which is acted upon by the water, and whatever, on the other hand, the substance acted upon by the heat. The motive power of a waterfall depends on its height and on the quantity of the liquid; the motive. power of heat depends also on the quantity of caloric used, and on what may be termed, on what in fact we will call, the height of its fall,* that is to say, the difference of temperature of the bodies between which the exchange of caloric is made. In the waterfall the motive power is exactly proportional to the difference of level between the higher and lower reservoirs. In the fall of caloric the motive power undoubtedly increases with the difference of temperature between the warm and the cold bodies; but we do not know whether it is proportional to this difference. We do not know, for example, whether the fall of caloric from 100 to 50 degrees furnishes more or less motive power than the fall of this same caloric from 50 to zero. It is a question which we propose to examine hereafter.
“Every change of temperature which is not due to a change of volume or to chemical action (an action that we provisionally suppose not to occur here) is necessarily due to the direct passage of the caloric from a more or less heated body to a colder body. This passage occurs mainly by the contact of bodies of different temperatures; hence such contact should be avoided as much as possible. It cannot probably be avoided entirely, but it should at least be so managed that the bodies brought in contact with each other differ as little as possible in temperature.”
After a while, Carnot concludes that the maximum work a given quantity of heat can do in a cycle is achieved when all the heat is absorbed at a high temperature and emitted at a low temperature. This is a Carnot cycle.
What Carnot does not say just what *is* maximized. Later physicists added concepts like ‘reversible cycles’, but Carnot’s reasoning is independent of the existence of these concepts. It is important to understand that much of the supporting data, here and in later papers by Joule, Kelivn, Clausius, etc., is given by measured values of the specific heat of various substances.
Then, Carnot claims:
“The production of motive power is then due in steam-engines not to an actual consumption of caloric, but to its transportation from a warm body to a cold body, that is, to its re-establishment of equilibrium-an equilibrium considered as destroyed by any cause whatever, by chemical action, such as combustion, or by any other. We shall see shortly that this principle is applicable to any machine set in motion by heat.
Wherever there exists a difference of temperature, wherever it has been possible for the equilibrium of the caloric to be re-established, it is possible to have also the production of impelling power. Steam is a means of realizing this power, but it is not the only one. All substances in nature can be employed for this purpose, all are susceptible of changes in volume, of successive contractions and dilatations, through the alternation of heat and cold. All are capable of overcoming in their changes of volume certain resistances, and of thus developing the impelling power. A solid body-a metallic bar for example- alternately heated and cooled increases and diminishes in length, and can move bodies fastened to its ends. A liquid alternately heated and cooled increases and diminishes in volume, and can overcome obstacles of greater or less size, opposed to its dilatation. An aeriform fluid is susceptible of considerable change of volume by variations of temperature. If it is enclosed in an expansible space, such as a cylinder provided with a piston, it will produce movements of great extent. Vapors of all substances capable of passing into a gaseous condition, as of alcohol, of mercury, of sulphur, etc., may fulfill the same office as vapor of water. The latter, alternately heated and cooled, would produce motive power in the shape of permanent gases, that is, without ever returning to a liquid state. Most of these substances have been proposed, many even have been tried, although up to this time perhaps without remarkable success. “
The claim is that all Carnot cycles that absorb the same amount of heat and have the same operating temperature also have the same motive power. This is crucial, as it renders his results completely independent of the design of the engine, and of the constitution of the working body. Again, later physicists add in certain equations of state or assumptions regarding the microscopic structure of matter, but those restrictions do not imply the original concept is likewise restricted. In order to justify his claim, Carnot describes the effect of the working body on it’s environment and then writes down an assumption:
“It is impossible for a heat engine to have done positive work yet have restored to the furnace all heat it previously absorbed from it and have withdrawn from the refrigerator all the heat it previously admitted to it.”
This is (historically) the first statement of the second law of thermodynamics.
Carnot’s work left many things undefined. Clayperon translated Carnot’s ideas into mathematics in 1834, but this merely magnified Carnot’s weak mathematics. Much of your book is based on Clayperon’s original essay, specifically the confusion between the general physical principle and the constitutive properties of a specific material.
That’s enough for today, I think… I have to prepare for class. Let me know what you think, what you want to discuss next, etc.
Beautifull stuff, Andi!
I really enjoyed reading, only missed some pop corn!
I am curious about your remark in the first post about the difference of thermostatics vs. thermostatistics. However personally, I think the insight, that thermodynamics (or thermostatics if you wish) refers to transitions between equilibrium states, was a big step forward: You can define temperature properly via the zeroth law, you drastically restrict the degrees of freedom so that you often only so become able to assign them at all. And you can define heat as the difference of the work done in an adiabatic process - which is assumed to be a state variable named U - and the heat done in the actual process operating between the same equilibrium states.
The articles by Coleman seem to refer to what is sometimes known as "rational thermodynamics", of which I don't know anything but that it is usually subsumed under linear irreversible thermodynamics. One possible criticism from a look at the papers: Coleman assumes the stress tensor to depend (among other things) on the history of absolute temperature. (There are many "We assume" in the article especially about the dependence of stress and heat on strain and temperature). But temperature is defined by the system being in equilibrium with the thermometer. How can you even define equilibrium for a time dependent process?
Furthermore the theory seems to be stream lined to discuss some rather specialized visco-elastic properties.
Don't get me wrong: I don't want to say that these papers don't contain some very interesting physics, I only doubt that they really extend on the range of thermostatics.
I'd just like to mention that there was another revival in classical thermodynamics at the beginning of the 20th century with the works of Max Planck (who did his thesis on it and, also maybe not directly, finally led him to discover quantum mechanics.) and Constantin Caratheodory, who both formulated some clever versions of the second law.
<snip>
Thanks, I appreciate that. Honestly, I enjoy discussions like this.
To your questions- I recommend you first unlearn all that stuff about 0th law, states, etc. We will add them back in as needed, but for now we don't need it. Because you are correct- defining an absolute temperature scale involved restricting systems to equilibrium systems. For over 100 years, that sufficed in Physics because of smart people that could tweak the concept to include things like 'local equilibrium' and 'detailed balance'. But now we have reached the end of those concepts; we can try to expand statistical methods to include fully dynamical systems (as many people are doing), or we can re-examine the fundamental thermodynamic concepts and re-develop them (the continuum program),
I'll be explicit- thermodynamics is currently a continuum theory only. SM is, for the purposes of this post, a different theory with different aims and axioms.
"rational thermodynamics" incorporates the axioms of thermodynamics to continuum mechanics. For example, wcg1989's formula is a balance equation, similar to those of mass, momentum, and energy. As I have posted elsewhere, a fundamental aim of continuum mechanics to is to specify the constitutive relations- the response of a material to an external force, if you like. It is an open problem, although there has been much progress in defining allowed classes of constitutive relations: materials with no memory, materials with memory, linear, nonlinear, idealized, etc. etc. Continuum mechanics is a fully axiomatized physical theory- the only one.
You are correct- the thermodynamic definition of absolute temperature currently holds only for equilibrium conditions. But it's clear that that definition needs to be updated-not just becasue of non-equilibrium considerations, but also from problems involving granular media, information theory, and relativity (Unruh radiation). Here's a paper you may find of interest:
http://www.physics.montana.edu/students/gilmore/iop_relativistic-thermo.pdf
Andy,
Thanks for posting that excerpt and for your commentary. There are three things that stick out to me. One is that the analogy that Carnot used with a waterfall is brilliant. Quantity of water with energy (although he didn't call it that) and height with temperature difference. Genius.
Second, what is as intriguing to me is that from the writing it appears that there were careful experiments that measured the motive power (work) based on a given amount of heat produced and a difference in temperature that it is allowed to "fall" through a process. What kind of experiments were these? How were these done and was he proposing that the results were the most amount of work that one could get based on the heat input and temperature difference.
And third, since he clearly was able to do experiments on heat and show work from it, it seems in hindsight that Joules experiment showing heat from work, shouldn't have been that big of surprise, but from further reading on Wikipedia, it was because the theory that Carnot was using called the "Caloric" was different than our concept of energy because the "Caloric" could be destroyed, not conserved.
Wayne
Edited:
I calculated the maximum possible efficiency for each experiment based on the information that you had summarized.
First just based on the work and heat input the actual efficiency for each experiment is:
Exp 1: eff = 1.395/1000 = 0.1395%
Exp 2: eff = 1.112/1000 = 0.1112%
However, the maximum possible efficiencies are based on the equation that we now know.
Max Eff = (TH-TL)/TH = 1/TH because the temperature difference (TH-TL) is 1 degree for both these experiments.
Assuming that he was using a Celsius/Kelvin scale, the maximum efficiency would be
Experiment 1:
Max eff = 1/(274.15) = 0.364%
Experiment 2:
Max eff = 1/(373.15) = 0.267%
Even if you use a Fahrenheit/Rankine scale, its:
Exp 1 :
Max eff = 1/(460.67) = 0.21%
Experiment 2:
Max eff = 1/(559.67) = 0.178%
So the experiments were definitely not the maximum efficiency possible and don't represent the efficiency of a Carnot cycle. But by measuring efficiencies and putting it in terms of heat input and temperature difference, it was instructive and opened up a whole new way of thinking about heat and work!
A couple of comments about Carnot.
I understand that Carnot subscribed to the caloric theory of heat, popular in his time.
Carnot was the only expositor of second law type statements to make a positive statement.
"Whenever a temperature difference exists, motive power can be produced."
As you have noted others stated the impossible.
wcg1989 said:
Andy,
<snip>
<snip>
You are raising good questions- it's important to remember that there were, AFAIK, *no* experiments done on engines. The entire theory of thermodynamics (and of processes) was based solely on measurements of specific heats. I don't have the time right now to draw a detailed line between specific heat and entropy, but heuristically, the measurement answers "how much heat moves around during a given process?" This amount of heat C is given from the (then) theory of calorimetry:
C=\int [\Lambda_{V} (V, T) dV + K_{V} (V,T) dT]
Where the integral is over the path of the process, \Lambda_{V} (V, T) is the latent heat at constant volume, K_{V} (V,T) the specific heat at constant volume, and 'T' should not be confused with the (later) absolute temperature. Both latent and specific heat are allowed to vary with time, as well. So a measurement of K_V, plus the relevant constitutive relations for What I don't have time for is how to get the Joule-Thompson coefficient mu from this:
http://en.wikipedia.org/wiki/Joule–Thomson_effect
And that is the key function used to define absolute temperature (and entropy). I don't dispute your calculations, but again, AFAIK, there were no experiments done on heat engines at the time.
Sorry- it's "science day" here today, and I have to get my lab ready for the incoming hordes...
I had a look on the interesting article on temperature concepts you provided, but I don't see that any of these definitions is too promising as a generalization, or even replacement, of the usual definition in terms of the zeroth law.
Thanks Andy. Good luck on science day.
That was some useful insight but it seems to me that the use of measured specific heats and calculation of the caloric with the integral doesn't come up with the most efficient and therefore maximum work that is possible for a given heat input and temperature difference? Otherwise, if it did provide the most efficient work, and if Carnot had been using it, wouldn't Carnot have come up pretty easily with the equation that was later developed for his cycle?
efficiency = (TH-TL)/TH
My understanding was that that was not really expressed until later when Kelvin stated
QH/QL = TH/TL which can be used to change the efficiency from an expression of heat inputs (QH-QL)/QH to one of temperature differences (TH-TL)/TH.
This statement is false:
Also, strictly speaking there is no such thing as thermodynamics. Strictly speaking it is always thermostatics.
The entropy of a system can only be rigorously defined within the statistical framework. There is no rigorous definition of entropy within "thermodynamics".
The second law is certainly derivable form within statistical mechanics as most textbooks on the subject will point out. Of course there are assumptions here (e.g. you need to assume special initial conditions), but these assumptions underly all of statistical mechanics and thermodynamics.
This is potentially a very interesting thread, and I for one do not have the answer.
It would be very sad if the original question was lost in a fundamentalist wrangle over definitions that came after the time period wcg1989 is enquiring about.
I agree- that's why it's still an open research problem :)
That was some useful insight but it seems to me that the use of measured specific heats and calculation of the caloric with the integral doesn't come up with the most efficient and therefore maximum work that is possible for a given heat input and temperature difference? <snip>
That's a good question, and one I need to think about how to best answer. For now, all we know is:
1) A Carnot cycle (accepting heat at a hot furnace and rejecting it at a cold refrigerator) is the most efficient cycle,
2) All Carnot cycles operating between the same temperatures and moving the same amount of heat have the same efficiency,
3) There is an upper limit to the amount of work that can be extracted from a given amount of heat.
Let me think a bit...
Provide a reference for this, please.
Fundamentals of Statistical and Thermal Physics by F. Reif
What page? I have a copy.
In don't have the book with me right now. However, he constantly uses reasoning like that "all accessible states are equally likely" and then invoking Omega function to explain why entropy increases etc. etc. From the beginning of the book right until the end when Brownian motion and other non-equilibrium phenomena are discussed.
Ok... here goes. The relevant math will be presented as summary statements, with many symbols not explicitly defined (here), and please remember that when I write 'T', 'p', 'V', 'S', it's to avoid writing the usual thermodynamic '\theta, \varpi , \Gamma, etc.. Time is an explicit part of this development.
First, the basic axioms of thermodynamics:
1) first law: \dot{E}= W + Q , where the overdot means differentiation with respect to time, and W and Q are rates of working and heating.
2) second law: Q \leq B, where B is the least upper bound for heating. That is, there is a limiting rate at which a body may convert heat into energy without doing work. This statement is but one of the many, many different equivalent statements, each calling themselves 'The' second law.
Defining S_{t,t_0} = \int B/T dt, the second law becomes T\dot{S}\geq Q. Note, we *defined* the entropy S this way, without any context. The units of Entropy is not energy, but an energy per unit degree. The second law can then be integrated and written as
\int Q dt \leq TS_{t-t0}-\int \dot{T}S dt, with implicit integration limits of t_0 and t.
From those 2 axioms, we can then define adiabatic (Q = 0), isentropic (\dot{S} = 0), and isothermal (\dot{T}=0) processes.
Now, we define a process as 'reversible' if the integral formula above is an equality for all times 't'. It's also useful to define the free energy F = E-TS, in which case the second law is written as:
\dot{F} - W + S \dot{T} \leq 0
This is (nearly) the entirety of thermodynamics- the two equations written above are satisfied for any physically realizable deformable body undergoing any physically realizable process. Obviously, they are not of much help in predicting what will happen to a *specific* body undergoing a *specific* process. For that, we now require constitutive relations- we require functions, for example:
W = W(T, V)
F = F(T, V)
S = S(T,V)
I will now work two examples- first, using the 'classical equations of state', and then adding 'linear friction'.
For the classical equations of state, we have:
W = -p(T, V)\dot{V}
F = F(T, V), S = S(T, V)
The second law becomes: (\frac{\partial}{\partial T} F + S)\dot{T} + (\frac{\partial}{\partial V} F + p)\dot{V} \leq 0
Which can only be satisfied if S = -\frac{\partial}{\partial T} F and p = -\frac{\partial}{\partial V}F.
These should look familiar, though maybe written in a 'strange' way. Now, linear friction (a quadratic term is added):
W = - p(T, V)\dot{V} - p_{12}(T, V) \dot{V_{1}}\dot{V_{2}}
Going through the same process as above for 'ideal gases' results in the 'residual heating' B - Q = -p_{12}(T, V)\dot{V1}\dot{V2}. This is what we expect: frictional processes result in heat that is unavailable to be used to perform work (remember the inequality above, which corresponds with B-Q).
Other constitutive relations can be used (and there are hundreds), with the same procedure used to generate other thermodynamic relationships.
Ok, so much for classes of bodies. Now what about classes of processes? Again, we define:
Work done by the body: W = \int p \dot{V}dt
Heat gained by the body C = \int Q dt
using the basic constitutive relations J\Lambda_{V} = T \frac{\partial p}{\partial T} and \frac{\partial}{\partial T}(\frac{\Lambda_{V}}{T})=\frac{\partial}{\partial V}(\frac{K_{V}}{T}), the first and second laws can be written in terms of the latent and specific heats:
\Lambda_{V} = T\frac{\partial S}{\partial V}, K_{V} = T \frac{\partial S}{\partial T}, J \Lambda_{V} =p+ T\frac{\partial E}{\partial V}, J K_{V} = \frac{\partial E}{\partial T}
J is the value Joule measured in his experiments.
And so, Q = T\dot{S}[/itex] and \dot{E} = JQ - p \dot{V}<br /> <br /> These can be formally integrated to give \Delta S =\int \frac{Q}{T}dt and \Delta E = JC - W.<br /> <br /> For a Carnot cycle, W/C_{abs} = J(1-T^{-}/ T^{+}), or C_{emit}/C_{abs} = T^{-}/ T^{+}. This is Kelvin&#039;s result.<br /> <br /> A more general bound can also be found: W+ \Delta E \leq J(1-T^{-}/ T^{+}) C^{+} + T_{min}\Delta S.<br /> <br /> Now, why do all this? Surely, using ideal gases and equilibrium states makes this much briefer. However, I feel that it also obscures the general nature of thermodynamics; for example, the results on linear friction and general bound on engine efficiency (and many others) are excluded by assumptions of equilibrium.
<snip>
I eagerly await an actual reference supporting your first sentence.
Andy,
Thanks for the response. Interesting analysis and one that will take me some time to digest. I've been out of school for decades now, so I'll have to open up the old math closets in my brain to pull in that one.
Maybe I'm over-simplifying this but in Carnot's paper when he talked about 1.395 units of motive power (work) coming from 1000 units of heat with a 1 degree drop was that representative of an isentropic process meaning was that really the maximum work that could have been pulled from that heat with that drop in temperature?
Strange stuff! What assumptions are implicit in your formulation of the second law? Is T the temperature of the surrounding, does it have to be equal to the temperature of the system? I don't see that there is any limit B as long as you don't specify the temperature of the surrounding.
I interprete your procedure as follows: The system under consideration is in contact with a heat bath of temperature T(t) and has a volume V(t), both time dependent.
Then however, neither E nor W nor S can be a function of (momentary) T and V as they will depend on the whole history of these parameters. This implies also that the latent and specific heats are functionals of the complete V and T history. I strongly doubt that anybody at the time of Carnot was able to determine these quantities.
wcg1989 said:
Andy,
Maybe I'm over-simplifying this but in Carnot's paper when he talked about 1.395 units of motive power (work) coming from 1000 units of heat with a 1 degree drop was that representative of an isotropic process meaning was that really the maximum work that could have been pulled from that heat with that drop in temperature?
here's another reference that's pretty good:
http://iopscience.iop.org/1478-7814/23/1/315/pdf?ejredirect=migration
On page 170:
'Employing his data, the value of F'(t), or the work done in a
cycle per degree fall per unit of heat supplied, comes out 1.395
kilogrammetres per kilocalorie per degree fall at 0°C. This
method of calculation, based on the work done in a cycle, does
not, like that of Mayer or Clausius, involve the assumption that
the whole work done in isothermal expansion is equivalent to the
heat supplied, which is true only for a perfect gas. Carnot's
method applies to any gas or vapour, however imperfect, and
would give the same result exactly for all substances at the
same temperature if the experimental data were correct. The
absolute equivalent of the kilocalorie is obtained, as explained
in the last section, by multiplying this result by the absolute
temperature corresponding to 0°C. on the scale of a perfect gas namely,
273-which gives 380 ktlogrammetres for the mechanical
equivalent of the kilocalorie. The discrepancy from the
true value, 427 kilogrammetres per kilocalorie, is due merely to
errors in the experimental data."
The number 1.395 does not refer to engine efficiency, it refers to the absolute value of entropy. Implicitly mentioned is an absolute temperature scale.
Does that help?
Yes it does. Thanks for the reference. The last sentence that refers to
"The discrepancy from the true value, 427 kilogrammetres per kilocalorie, is due merely to
and that sort of fills me in on what I was trying to grasp. Namely that through the use of measurements of specific heats, and some calculations, that Carnot was trying to show in his paper the reversible work from a given heat input and temperature fall at a given temperature or as you referenced
"'Employing his data, the value of F'(t), or the work done in a
Maybe his math was poor but I'm understanding better why Carnot was held in such high regard as one of the fathers of thermodynamics.
References are actually irrelevant here, this can be settled using simple physics arguments.
Thermodynamics withoiut a statistical foundation does not make sense. Suppose you consider the heat flow in some system and then you make an identical copyy of that system where "identical" means that it has the same thermodynamic description.
Then we all know that the the energy flow will not be exactly the same sue to the fact that there are statistical fluctations. This then means that the symbols you write down when taken literally, have to be understood as some sort of ensemble averages. Whether you choose to be explicit about that or not, doesn't matter. You may choose to not to elaborate on that, but that doesn't mean that the statistical fluctuations aren't there.
As best I can understand, the 2 fundamental axioms (which can written in several equivalent ways) are axioms/postulates/definitions. There are no assumptions built into them. Writing down constitutive relations *does* involve assumptions- for example, an ideal gas has no memory, a Carnot cycle requires two thermal reservoirs, a process is continuously differentiable, etc.
There are 'rules' for constitutive relations- causality is one, equipresence is another; but it's certainly possible to write down a constitutive relation for a nonlinear material with memory. I tried writing down a LaTex example, but when I 'Preview Post' it comes out totally incoherent... Anyhow, the literature is replete with such constitutive relations.
You are also correct that writing down such a general constitutive relation makes the results very difficult to interpret.
<snip>
This is anti-science.
  • #31
wcg1989 said:
<snip>
Excellent!
  • #32
Putting forward scientific arguments is not "anti-science". Anyway, just tell me how you got rid of the statistical fluctuations in your energy flows and other quantities?
So, basically my point is that the statistical foundations are simply hidden in the assumptions you make. Not elaborating on those assumptions does not mean that the statistical foundations aren't there, even if scientists haven't worked out yet how to do this rigorously.
  • #33
Count Iblis, classical thermodynamics - about which we are talking here - always refers to the limit of the system size to become infinite (at fixed density), where fluctuations become irrelevant.
  • #34
Yes, I largely agree, but the transport phenomena which Andy no doubt does want to describe in his thermodynamic treatment do depend on the fluctuations. What happens here is that one considers a deviation from global thermal equilibrium and then the fluctuations are essential to understand how the system will tend to restore global thermal equilibrium.
  • #35
Your 'arguments' are not anywhere close to scientific, they are a logorrhea of random rhetorical statements.
But fine, now you actually bring up something concrete. Whence fluctuations?
Transport is handled in continuum mechanics by means of balance equations. Brenner's text "Macrotransport Processes" is an excellent starting point, and Slattery's "Interfacial transport phenomena" may even be better. But how do we model fluctuations in the continuum picture?
I'll first note that the fluctuations are occurring *about equilibrium values*. Fluctuations cannot be defined without equilibrium.
Answer: By means of the fluctuation-dissipation theorem. I'm not sure what fluctuations mean in a fully dynamic situation. But if you want to restrict yourself to near-equilibrium conditions, go for it.
  • #36
I really enjoyed the part of Carnot's paper that made an analogy with the Paddle wheel. (I can wrap my engineer brain around that one!) For the heck of it, I did my own calculations showing the analogy. No integrals or statistical equations! Just some really basic undergraduate stuff.
The 2nd law says the maximum efficiency possible of a heat engine is
eff = 1 - TL/TH
where TH is the high temperature of the heat going into the engine and TL is the low temperature. And eff is defined as
W = Eff * Qin
where W is the useful work and Qin is the heat energy going into the process also called QH.
This is analogous to how a paddle wheel works. The maximum possible work rate (power) from a flow over a paddle wheel is defined by the potential energy
W = mgh
where W is a work rate and m is the mass flow rate. That’s the maximum possible. Friction in the wheel causes the real work to be less but this is the maximum possible.
But look at h. If we think of it as over sea level and not just the height of the wheel we can form this another way and think about the maximum potential work of the paddle wheel vs the potential work of the wheel if the wheel extended all the way down to sea level. For this example assume sea level is as absolutely low as one could possibly go, no holes in the ground!. Then we can say
W = mghH - mghL
where hH is the top of the wheel and hL is the bottom of the wheel and both are defined as the height over sea level.
If hL is 0 or sea level then the equation above would be the maximum amount of work possible based on the initial height (hH) of the water going into the wheel.
I can rewrite the equation above through algebra
W = mghH * (1-mghL/mghH)
or
W = mghH * (1-hL/hH)
And if I defined best efficiency possible as (1-hL/hH) then
W = eff * mghH
And that is the same as the thermal efficiency through analogy! The potential energy of the flow going into the wheel mghH is analogous to the thermal energy going in the system, QH. The best efficiency based on height difference (1-hL/hH) is analogous to the best efficiency possible through temperature difference, 1-TL/TH
And this makes sense too. The objects in the room around us have a tremendous amount of thermal energy in them. But they are all about the same temperature. If there is no temperature difference, no where for the thermal energy in the room to "flow down" then no work can be made. And that's the analogy.
  • #37
That's really excellent- mind if I use it in my Physics I class next semester?
  • #38
Thanks for the compliment!
I think it would be cool if that was taught as a lesson in a physics class. This stuff is more interesting then the daily grind of being an engineer. But I suppose that is what I'm suppose to be doing right now! Gotta go.
  • #39
Andy Resnick,
Thank you for this discussion. I am certain that blis is wrong and you are correct. It is not often that such diverse views are openly debated about something so fundamental as Thermodynamic Entropy. The difference that you point out between Clausius' definition and alternative definitions that followed is, I think, very important to fundamental scientific learning. The difference between the obvious inclusion of time in Clausius' definition and the leap to other definitions that are static is critical to fundamental understanding. I think it demonstrates that we do not yet know what Thermodynamic Entropy is. I think that understanding the role of 'time' in Clausius' definition is important for explaining why Thermodynamic Entropy is a process that takes time. The question, as I see it, is why does Thermodynamic Entropy require time? I would appreciate reading more of your input even if what I have said does not conform to it.
James Putnam
  • #40
Well I don't think there are any real disagreements about the physics. From a fundamental POV, the fluctuations cause the transport phenomena, but you can describe these phenomena in an effective way.
  • #41
Iblis,
Sorry for missing the 'I' in your name.
"..From a fundamental POV, the fluctuations cause the transport phenomena, but you can describe these phenomena in an effective way."
How does static produce fluctuations?" Clausius did not require fluctuations. In the ideal situation that he relied upon there were no fluctuations. Is this incorrect?
James
  • #42
Andy Resnick said:
<snip>
I was going to edit this, but since there have already been comments, I'll just do it this way:
It makes no sense to speak of fluctuations in a fully dynamical theory. What you are asking for is to first, remove the dynamics and then add them back in, in such a manner that requires statistical notions. In which case you can start with the Langevin equation or Smoluchowski equation. In the end, continuum mechanics is recovered.
Fluctuations 'cause' transport *only in a static theory*. In a dynamic theory, we have balance equations- have you heard of flux?. To be sure, in the quantum mechanical view, fluctuations occur in a more fundamental sense- but that's when I would rely on the fluctuation-dissipation theorem. And again, continuum mechanics is recovered.
In the end, Iblis, I really don't understand what your objection is to anything that I have written.
  • #43
James A. Putnam said:
Andy Resnick,
<snip>
James Putnam
I think I understand your question, and I would answer it this way:
Asking what entropy 'is' (or what temperature 'is'), is very similar to asking (in the context of mechanics) what mass 'is'. In mechanics, we can't answer very much beyond 'mass is how much stuff there is'. And that is generally accepted without further comment. Recall that the first and second laws of thermodynamics are assertions- they are not derived from anything.
Now, it is clear there is some connection between entropy and *temperature*. In thermodynamics, there is not (AFAIK) a 'problem of the direction of time'. Irreversible processes (and time-dependent processes) pose no real conceptual issue: see my results on linear friction posted earlier. Put another way, When Joule's weight drops and the water heats up, we are not surprised. But we would be *very* surprised if instead, we heated the water and the mass raised up, cooling the water.
There are many unsolved problems in Thermodynamics (limit of small size is an obvious one, wetting is another), but relating entropy change and time is not one of them.
  • #44
Andy Resnick,
Absorbing energy under equilibrium conditions requires time. As thermodynamic entropy changes so does something that relates to time. Why do you say that a process that requires time does not relate to time? Perhaps I do not understand your point. How does thermodynamic entropy change without relating it to a change in time?
James
  • #45
Andy Resnick,
I should have added that the following questions are important to answer before moving on to higher level theory that includes them.
"...Asking what entropy 'is' (or what temperature 'is'), is very similar to asking (in the context of mechanics) what mass 'is'. ..."
What is Thermodynamic Entropy? What is temperature? What is mass? I think they are each required to be answered in order to advance theoretical physics. However, the most immediate one is: What is mass? The answer to this question could change almost everything.
James
  • #46
Iblis,
The truth is that I would like to read your answers first. The subject of this thread justifies responding only to: What is Thermodynamic Entropy? What is it that Clausius discovered? Did he discover microstates?
James
  • #47
James, I think one of the reasons entropy is less understood and has acquired a special mystique is the question of the system boundary.
If we think of energy we are comfortable with notions of where it come from and where it goes to. We have energy conservation laws. We can collect it in a container, store it, transport it, release it at will.
But if we think of entropy where is it located?
When entropy increases where does it come from?
Is it possible to fill my beer glass or other container with entropy?
  • #48
Andy Resnick,
Absorbing energy under equilibrium conditions requires time. <snip>
James
This is one of the notions I hope to disabuse you of. Maybe you are thinking of steady-state conditions, but at equilibrium, there can be *no* absorption. That's part of the definition of equilibrium!
  • #49
Andy Resnick,
James
I disagree we need any definition other than:
"mass" is how much stuff there is
"temperature" is how hot something is
I confess, I don't have such a short, clean, definition of entropy (yet). Some people claim we need to understand where mass 'comes from' (i.e. Higgs mechanism), and while I don't disagree with their overall goal, I also note that continuum mechanics will be changed not a whit by future theories about the origin of mass, and thermodynamics will be changed not a whit by "understanding the origin of entropy and temperature".
It's similar to the occasional post around here, claiming that to understand how light reflects or refracts, we first have to understand quantum electrodynamics. It's a foolish notion and unhelpful for students.
  • #50
Andy Resnick,
"...This is one of the notions I hope to disabuse you of. Maybe you are thinking of steady-state conditions, but at equilibrium, there can be *no* absorption. That's part of the definition of equilibrium! ..."
Clausius defined thermodynamic entropy by allowing for absorbtion under conditions of equilibrium. Is this an incorrect statement?
From your following message:
"...Some people claim we need to understand where mass 'comes from' (i.e. Higgs mechanism), and while I don't disagree with their overall goal, I also note that continuum mechanics will be changed not a whit by future theories about the origin of mass, and thermodynamics will be changed not a whit by "understanding the origin of entropy and temperature. ..."
Ok I get your point, though I think it has to do with what is debatable here and not with what is settled science. I disagree completely with it, but I respect your position. I will not press the issue here.
James
