- 7,833
- 4,177
wcg1989 said:<snip>
Maybe his math was poor but I'm understanding better why Carnot was held in such high regard as one of the fathers of thermodynamics.
Excellent!
wcg1989 said:<snip>
Andy Resnick said:This is anti-science.
DrDu said:Count Iblis, classical thermodynamics - about which we are talking here - always refers to the limit of the system size to become infinite (at fixed density), where fluctuations become irrelevant.
Count Iblis said:Putting forward scientific arguments is not "anti-science". Anyway, just tell me how you got rid of the statistical fluctuations in your energy flows and other quantities?
So, basically my point is that the statistical foundations are simply hidden in the assumptions you make. Not elaborating on those assumptions does not mean that the statistical foundations aren't there, even if scientists haven't worked out yet how to do this rigorously.
Andy Resnick said:<snip>
Transport is handled in continuum mechanics by means of balance equations. Brenner's text "Macrotransport Processes" is an excellent starting point, and Slattery's "Interfacial transport phenomena" may even be better. But how do we model fluctuations in the continuum picture?
I'll first note that the fluctuations are occurring *about equilibrium values*. Fluctuations cannot be defined without equilibrium.
Answer: By means of the fluctuation-dissipation theorem. I'm not sure what fluctuations mean in a fully dynamic situation. But if you want to restrict yourself to near-equilibrium conditions, go for it.
James A. Putnam said:Andy Resnick,
<snip>
I think it demonstrates that we do not yet know what Thermodynamic Entropy is. I think that understanding the role of 'time' in Clausius' definition is important for explaining why Thermodynamic Entropy is a process that takes time. The question, as I see it, is why does Thermodynamic Entropy require time? I would appreciate reading more of your input even if what I have said does not conform to it.
James Putnam
Absorbing energy under equilibrium conditions requires time. <snip>
James
I should have added that the following questions are important to answer before moving on to higher level theory that includes them.
"...Asking what entropy 'is' (or what temperature 'is'), is very similar to asking (in the context of mechanics) what mass 'is'. ..."
What is Thermodynamic Entropy? What is temperature? What is mass? I think they are each required to be answered in order to advance theoretical physics. However, the most immediate one is: What is mass? The answer to this question could change almost everything.
James
James A. Putnam said:Iblis,
"...Also: The mass of an object is the total rest energy of the object. ..."
What is the total rest energy of the object? In other words, what is the material composition of energy whether rest or otherwise?
James
Count Iblis said:That depends on the interactions in the system. Particles get their rest energy from the interaction with the Higgs field as Andy pointed out. But bound states of particles will contain extra energy (e.g. the mass of the proton is mostly due to the interaction between the quarks and not the masses of the quarks).
Exotic example. Take 6 square mirrors and make a cube out of it that encloses a perfect vacuum. Then the total energy of the cube is due to the rest energy (mass) of the 6 mirrors plus the Casimir energy of the enclosed vacuum. The mass of the empty cube is thus slightly more than the mass of the 6 mirrors.
Count Iblis said:Andy, I don't think we disagree on the physics itself. \
Count Iblis said:Also, strictly speaking there is no such thing as thermodynamics. Strictly speaking it is always thermostatics.
The entropy of a system can only be rigorously defined within the statistical framework. There is no rigorous definition of entropy within "thermodynamics".
Count Iblis said:Thermodynamics withoiut a statistical foundation does not make sense.
Count Iblis said:So, basically my point is that the statistical foundations are simply hidden in the assumptions you make.
Count Iblis said:From a fundamental POV, the fluctuations cause the transport phenomena, but you can describe these phenomena in an effective way.
Count Iblis said:Yes, bound states of protons and neutrons forming a nucleus will have a lower mass than the sum of the masses of the neutrons and protons. However, in case of the QCD forces between quarks you get the opposite effect, see here:
http://en.wikipedia.org/wiki/Proton#Quarks_and_the_mass_of_the_proton
So, you need to compare the energy of the system relative to some reference state. Now, you don't get free quarks when you pump more energy in a proton, you actually get further away from such a state. But perhaps some expert in QCD can explain that better than I can...
About the Casimir energy, I remember reading somewhere that for a cube this is positive, but I'm not 100% sure...
You have a fatally flawed understanding of the subject, and are apparently not interested in correcting it.
