Difference in pressure question
The discussion revolves around calculating the pressure difference in the Alaskan pipeline when the radius changes from 60 cm to 35 cm. The initial pressure is given as 160 kPa, and the density of oil is 800 kg/m³. The user attempts to find the pressure at the narrower section using Bernoulli's equation but encounters an incorrect result. Participants suggest that the user may have miscalculated the velocity due to confusion between flow rate and speed. Clarifications on dynamic versus static pressure are also raised, indicating a need for better understanding of the problem's requirements.
grog
The alaskan pipeline has a capacity of 2.37*105m3/day of oil per day. Along most of the pipeline the radius is 60 cm. Find the pressure at a point where the pipe has a 35 cm radius. Take the pressure in the section with radius 60 cm to be 160 kPa and the density of oil to be 800kg/m3. Answer in units of kPA
.5 * rho * v12+ rho * g * y + p1 = .5 * rho * v22 + rho * g* y + p2
since y = 0, we end up with:
.5 * rho * v12+ p1 = .5 * rho * v22 + p2
v2 = v1 ( A1 / A2)
v1 = 2.37x10^5 m^3/day = 2.743055556 m^3/sec
A1 = 60^2*pi = 11309.73355 cm^2
A2 = 35^2 * pi = 3848.451001 cm^2
v2 = v1 * (A1/A2)
p1-p2 (difference in pressure) = (.5)(rho)(v2^2) - (.5)(rho)(v1^2)
substitute:
= (.5)(rho) ((v1*A1/A2)^2) - (.5)(rho)(v1^2)
= (.5)(rho)(v1^2) [(a1/a2)^2 - 1]
plugging in:
= (0.5)(800)(2.743055556)^2 (7.636401493) = 22983.59459 Pa = p1-p2
since we're given p1 = 160 kPa, converting the difference in pressure to kPa and subtracting yields
22.98359459 = 160 - p2
p2 = 137.0164054 kPa
However, this is an in correct answer. Does anyone see where I'm making my mistake?
Hm.
Is the question asking for dynamic, static, or stagnation pressure?
The problem doesn't seem to specify. how would I tell, and how would that affect my answer?
Your error is in determining the speed. You seem to be mixing up flow with speed.
Since Flow = dV/dt = d/dt(Ax) = vA =&gt; v = Flow/A[/tex]<br /> <br /> For the 60 cm section, v = Flow/\pi r^2 = 2.74/3.14*.36 = 2.42 m/secAM
Thanks!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
