Diff Eq Sign Error - Seeking Second Set of Eyes
Saladsamurai
!For The Love of GOD! Diff Eq
I have done this problem 3 times. I am getting a sign error somewhere and I cannot find it.
When I solve this DE and then plug it back into the original, it is not checking out! Can anybody see my error? I would really appreciate a second set of eyes here. Clearly I am at that point where I just keep seeing what I think I am supposed to see!
Re writing the solution to the DE with the new constants is
x=-3/2\cos4t+3\sin4t+7/2\cos4t+1/2\sin4t=2\cos4t+19/4\sin4t
y=3\cos4t-7/2\sin4t
But when I differentiate and plug back into either if the originals, I am coming up with two sign errors...
At one point in your solution you have:
4 k_1+ (-2- 4i)k_2= 0
and then
k_1= \frac{-2- 4i}{4}k_2
It should be
k_1= \frac{2+ 4i}{4}k_2
and then
It should be
I do not understand why it should be positive? From the matrix I have 4k_1+(-2-\lambda)k_2 where lambda=4i...unless I am interpreting matrices wrong??
Basic Algebra.
4K1 - (2+4i)k2 = 0
K1 = (2+4i)k2/4
Vid said:
Basic Algebra.
4K1 - (2+4i)k2 = 0
K1 = (2+4i)k2/4
Okay. Obviously I am misinterpreting how a matrix operates. Not how to do basic algebra.
I was just kidding, maybe that was inappropriate...my bad.
If the original equation was
x'=2x-5y
y'=4x-2y
To find the charectaristic equation I create this matrix thing...I don't know what it is called
<br /> \left[\begin{array}{cc}2-\lambda &amp; -5 \\ 4 &amp; -2-\lambda\end{array}\right]=0
Now if I plug in \lambda= 4i to the 2nd row, how do you suppose I will get anything positive?
x'=2x-5y
y'=4x-2y
Can anybody see what I am doing wrong in this procedure? What am I misunderstanding?
If I plug \lambda=4i into -2-\lambda why would I get 2+4i ?
I have five more problems similar to this and cannot move on until I clear this up.
Any help would be great!
x'=2x-5y
y'=4x-2y
Kind of desperate here...
Do you still not see the glaring algebra error in the bottom left...?
Thank you. That's all I needed...
Your K1 value is where the sign error is. Change it to what Hallsofivy did and solve again from there.
