Differential equations, variation of parameters
missavvy
Using variation of parameters, find the general solutions of the differential equation
y''' - 3''y + 3y' - y = et / t
where et/t = g(t)
I know how to solve these types of equations when its a second order, but I don't understand what to do for the particular solution since there are 3 solutions to the associated homogeneous equation, y1 = et, y2 = tet, y3 = t2et.
Usually I would just take the 2 solutions and compute the Wronskian, then use the formula where it's -y1*integral([y2*g(t)]/W)dt + y2*integral([y1*g(t)]/W)dt.
Since there are three solutions though, I don't understand how to solve it. My textbook uses a different method where they use something like v1'y1 + v2'y2 + v3'y3 = 0, v1'y1' + v2'y2' + v3'y3' = 0, and then the next equation is the same except the y's are the 2nd derivatives and it = g(t).
Then they solve for v1, v2 and v3, integrate, and plug them into the homogeneous equation to get the particular solution.
Sorry if this isn't clear!
for Nth degree differential equation, there is a different formula.
http://img256.imageshack.us/img256/8756/dif2.jpg
Here, W(t) = W (y1,y2,y3,...,yn)(t)
and Wm(t) is the determinant obtained from W by replacing the mth column by the column (0,0,...,0,1)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
