Differential Geometry: Unit Normal Field
badgers14
Let M be the surface defined by z=x2+3xy-5y2. Find a unit normal vector field U defined on a neighborhood of p on M.
First, I reparameterized the equation for the surface to get x(u,v)=(u,v,u2+3xy-5y2). Next I found two tangent vectors xu(u,v)=(1,0,2u+3v) and xv=(0,1,3u-10v). The next step is where I'm unsure. In the text it gives an equation for the unit normal function, U=(xu X xv)/||xu X xv||. When I use this equation, I come up with
U=(-2u-3v,10v-3u,1)/(sqrt(13u2-54uv+109v2+1)
This just seemed messy to me, not sure if I'm missing something or if that is actually what the answer should look like. Any verification/help would be appreciated
Sure, it's a little messy. I think you are doing everything basically correctly, except you mean x=u and z=v and in z(u,v) you forgot to replace some of the x's and y's with u's and v's. And in the final result I don't agree with your coefficient of uv in the denominator.
Thank you, and here is a follow up question that I'm having a little difficulty with.
Compute the covariant derivatives \nablau1U and \nablau2U at p=(0,0,0). Where U is the unit normal vector computed in part (a) and with tangent vectors u1=(1,0,0) and u2=(0,1,0).
First, I computed U at (0,0,0) which was the upward unit normal (0,0,1). From here I'm not sure what the next step is.
I'm not sure either. What's your definition of covariant derivative? It looks to me like they must want the covariant derivative in three dimensional space with the usual metric, in which case the Christoffel symbols are zero, and it's pretty much the usual derivative.
I found this via Google while looking for something else, but it seems by the opening poster's name and the question that we are in the same class at the same university.
We are using Elementary Differential Geometry by Barrett O'Neill and our definition of covariant derivative is:
Let W be a vector field on R3, and let v be a tangent vector field on R3 at a point p. Then the covariant derivative of W with respect to v is the tangent vector \nablavW = W(p + tv)' at the point p.
@badgers14, I have not done the computations for these problems yet, but I will make another post and let you know what I come up with.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
