Double Integral: Find Area of Triangular Vertices
haris13
find the area of the double integral ∫∫x + y (is the triangular vertices (0.0) , (2,2) and (4,0)) how to find the values of x and y.
What have you tried? Before we can give you any help, you must have made an effort to solve the problem.
Also, I'm not sure that you understand the problem. I believe that you are to evaluate this integral
\int \int_R x + y~dA
where R is the triangular region with vertices (0, 0), (2, 2), and (4, 0). If so, the integral probably doesn't represent an area, and you are not supposed to solve for x and y.
You must first integrate with respect to one variable and then to another. First write the equations of the lines of your triangle (i will do this in terms of x). The range of your x values is 0 to 4. Now, y values range from 0 to y=x from x=0 to x=2, and y values range from 0 to y= 4 - x from x = 2 to x - 4.
The integral over the intire area can be separated into two simple double integrals:
the integral from 0 to 2 of the integral from 0 to X of (x+y), with respect to y, with respect to x
PLUS
the integral from 2 to 4 of the integral from 0 to (4-x) of (x +y), with respect to y, with respect to x
I'm sorry, still working on getting the symbols and correct boundaries to look nice, ill edit as soon as possible
And yes, you should have made an effort to solve... This wasn't meant to take anything away from the poster above... forgive me, I am new!
thanks for your help. I am fairly new at integrals so i was having a hard time. can you please give me the x and y values of both the intergrals of both parts. i still don't know how we arrive at those values. that's my only concern.
There are two ways to do this:
1. make your x-bound a numerical interval [a,b], and make the y-bound lines [y1=m1x+b1, y2=m2x+b2]
2. make your y-bound a numerical interval [a,b] and make the x-bound lines, [x1=m1y+b1, x2=m2y+b2]
You should try both ways just to see that they result in the same value.
What have you tried? Did you read my post #2?
From the Rules of this forum (emphasis added) :
Homework Help:
On posting questions: Any and all high school and undergraduate homework assignments or textbook style exercises for which you are seeking assistance are to be posted in the appropriate forum in our Homework & Coursework Questions area--not in blogs, visitor messages, PMs, or the main technical forums. This should be done whether the problem is part of one's assigned coursework or just independent study. The reason for this is that the scientific and mathematical sections of Physics Forums are to be reserved for discussions and not academic assistance. Since graduate level assignments are meant to be more thought provoking (and hence more worthy of discussion), graduate level questions will be allowed in the relevant part of the main section of PF, provided that the graduate student attempts the problem and shows his work.
NOTE: You MUST show that you have attempted to answer your question in order to receive help. You MUST make use of the homework template, which automatically appears when a new topic is created in the homework help forums. Once your question or problem has been responded to, do not go back and delete (or edit) your original post.
We do not support cheating in any form: Do not ask for solution manuals, answers to exams, or instructor's manuals. Every school and instructor has their own policies or honor codes on what constitutes cheating, and it is up to the individual student to adhere to those policies when seeking help here. If you are in doubt as to whether you are permitted to seek help, consider erring on the side of caution and not asking for help.
On helping with questions: Any and all assistance given to homework assignments or textbook style exercises should be given only after the questioner has shown some effort in solving the problem. If no attempt is made then the questioner should be asked to provide one before any assistance is given. Under no circumstances should complete solutions be provided to a questioner, whether or not an attempt has been made.
