Double Orthogonal Closed Subspace Inner Product => Hilbert
SqueeSpleen
Let X be an Inner Product Space. If for every closed subspace M, M^{\perp \perp} = M, then X is a Hilbert Space (It's complete).
Hint: Use the following map: T : X \longrightarrow \overset{\sim}{X}: T(y)=(x,y)=f(x) where (x,y) is the inner product of X.
Relevant equations:
S^{\perp} is always closed to every S \subset X
Attemp to solution.
I don't really know how to solve it, most theorems I have read, have Hilbert Space as a hyphotesis.
The only idea I had was trying to prove that \overline{T(M^{\perp})} = M^{\circ} (Where M^{\circ} is the Null Space of M).Edit: How do I do to have latex without jumping lines? I uploaded a pdf with a itext more closely formated to what I tried to write.
Edit2: I read other posts to find out how to do it, I only had to add an i to the "tex".
I'm thinking about the family of subspaces of \overset{\sim}{X}[\itex] that are intersection of nullspaces of one dimensional subspaces of X[\itex], they are all closed. I think that if I can probe that they're all closed subspaces of X[\itex] I may, somehow, be able to prove the required statement.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
