Dynamics and F=ma, where a is 0
  • Thread starter Thread starter FaithAlyRose
    Dynamics F=ma
A 24kg box on a 40° slope is moving downward at a constant velocity of 9.0 m/s, indicating zero acceleration. The frictional force must balance the component of gravitational force acting down the slope. A free-body diagram (FBD) is essential for visualizing the forces, including weight, friction, and the normal force. Participants emphasize the importance of correctly resolving forces into their x and y components to apply Newton's second law effectively. Understanding these concepts is crucial for solving dynamics problems involving friction and inclined planes.
FaithAlyRose
A 24kg box is placed on a rough slope. Determine the magnitude of the frictional force exerted by the slope on the box if the box is moving downward at a constant velocity of 9.0m/s. The slope incline is 40°
F=ma
F = 24 x 0
a = 0 because speed is constant.
Resultant force = Initial force - frictional force
What is that attempt? You seem to have learned things in way too hurry. First draw the FBD of the block. See what are the forces acting on it. How can it's acceleration be put to zero etc.,
Start with a free-body diagram. I encourage you to explain what you're doing instead of trying to make us guess what you reasoning is.
Well, as stated in the title, I used F=ma, so the working I came up with was F=24x0, with 24 being the mass of the box and 0 for the acceleration since the speed is constant.
Haha sorry, I'm still very new to Physics, as I'm only 13. Our teacher just started teaching us, but he's far from thorough so we're struggling...
For the FBD, I drew
1) weight acting vertically downwards
2) friction acting opposite the direction of motion
3) a force acting perpendicular to the incline of the slope
4) the direction of motion
Thanks for offering your help! :)
FaithAlyRose said:
F = 24 x 0
What do you mean by "initial force"?
I figured that's what you probably did, but it's better to hear you actually say it. Students can quite often come up with the correct answer for the wrong reasons.
FaithAlyRose said:
For the FBD, I drew
Choose a set of axes and resolve the forces into x and y components. Then set up two equations:
\begin{align*}
\sum F_x &= ma_x \\
\sum F_y &= ma_y
\end{align*} where, as you noted, you have ##a_x = a_y = 0## since the box moves at constant speed.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
