Dynamics - Pulley System with Rotating Rod
The discussion revolves around a dynamics problem involving a pulley system with a rotating rod. The original poster presents a scenario where the rod is rotating about its center, and various forces and moments are acting on the system. The goal is to determine the acceleration of a specific point on the rod.
  • The original poster attempts to derive equations of motion based on forces and moments acting on the system, while questioning the impact of angular velocity on the acceleration of point B. Other participants raise questions about the assumptions made regarding gravity and tension, and whether the acceleration of point B would be zero if only the rotation of the rod is considered.
The discussion is active, with participants exploring different interpretations of the problem. Some guidance has been provided, as one participant reflects on their understanding of the rod's motion and acknowledges a correction in their approach after considering the rod's rotation more closely.
The problem statement does not specify certain conditions, leading to varying interpretations among participants regarding the forces at play and the assumptions that can be made.
bonannic
At the instant shown, the rod R is rotating about its centre of rotation with ω=3.8rad/s.
mA=10kg;
The pulley, with mP=8.7kg and RP=0.2m, may be modeled as a uniform disc.
The rod, with mR=4.1kg and L=0.8m, may be modeled as a thin beam rotating about one end.
g=9.8m/s ².
What is the magnitude of the acceleration of point B at this instant?
ΣF=ma (N2) ΣM=Iα (Eulers equation)
IP=(1/2)MR2
IRod at centre of rotation=(1/3)ML2
I defined upwards and anticlockwise to be positive and thus derived the following equations:
ΣFA=TA-mAg=mAaA
ΣMP at centre=RpTA-RpTB=IPαP
ΣMRod at end=-LTB+(1/2)LMRg=IRαR
where TA= Tension force acting between A and pulley and TB=Tension force acting between rod and pulley
I then found these constraints on aB in terms of aAPR
-aB=aA
5aBP
(-5/4)aBR
assuming that aB is acting upwards
Then, by subbing aB into the three original equations, I got the following system of equations:
TA+mAaB=mAg
RpTA-RpTB-5IPaB=0
-LTB+(5/4)IRaB=-(1/2)LMRg
However, when I solve this system of linear equations I get the wrong answer. I have a feeling this is because I ignored the angular velocity of the rod but I can't see that would affect the acceleration of B.
If you ignored everything (gravity and tension) except for the fact that the rod is rotating. Would B have zero acceleration?
The question does not specify. All the information in the problem statement is all the information that the question gives.
It is not a question about the problem, it is a question to you.
Ah ok. So the end of the rod would be accelerating towards the pivot point as well.
I took this into consideration and got the right answer. I guess I should have studied the end of the rod more closely. Thank you so much for your help :)
  • · Replies 30 ·
  • · Replies 19 ·
13K
