Efficiency of a 10%-Efficient Car Engine: Energy Transfer and First Steps
A 10%-efficient car engine accelerates a 1700 kg car from rest to 18 m/s, prompting a discussion on energy transfer from burning gasoline. To determine how much energy is transferred to the engine, one must first understand the definition of efficiency and its implications on energy output. The kinetic energy gained by the car at 18 m/s is a critical factor in this calculation. The initial step in solving the problem involves identifying the kinetic energy formula and applying it to the car's mass and final velocity. Understanding these concepts is essential for calculating the energy input required for the engine's operation.
spokorne
A 10%-efficient car engine accelerates the 1700 kg car from rest to 18 m/s.
How much energy is transferred to the engine by burning gasoline?
What should be my first step in attempting this problem?
Ask yourself these questions:
1)What is the definition of efficiency?
2) If the car starts from rest and then to 18m/s, what kind of energy will it possess?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
