Electric Field and Charge Density
The discussion focuses on calculating charge density from an electric field using Gauss's Law. The electric field intensity is given as E(x) = \hat{x} Kx^3, where K is a constant, and the charge density is assumed to be a volume charge density. The user seeks clarification on whether the charge density is constant and how to derive it using Gauss's Law. The solution involves integrating the charge density over the specified region and relating it to the electric field through the equation E(x) = Q_total/(Aε0). Ultimately, the charge density is expressed as ρ(x) = (E(x)ε0)/A, leading to the final formula ρ(x) = (Kx^3ε0)/(2a).
jesuslovesu
[SOLVED] Electric Field and Charge Density
Oops, nevermind I guess I just use div(E) = rho/e0
A layer of charge fills the space between x = -a and x = a. The layer has a charge density \rho (x). The electric field intensity everywhere inside the charge distribution is given by E(x) = \hat{x} Kx^3 where K is a constant[/tex]
I asked my professor about this and he said the \rho(x) should be a volume charge density. So basically it's an infinite slab (in the y and z dir) Having some difficulty in finding the charge density.
I am assuming the charge density is NOT constant everywhere, correct?
I recognize that this requires a Gauss's Law formulation. Similar to an infinite plane if I am not mistaken.
E(A) = Qin/e0
E(2A) = \rho (x) * A * (2a)/e0
E = \rho (x) * a/e0
Can I just plug in E and rearrange to get \rho (x) ? Am I handling the ends correctly? I am basically following the same procedure for finding the E of an infinite plane except I am using 2a as the thickness.
SOLUTION:Yes, you can use Gauss's Law to solve this problem. First, we need to calculate the electric field at a given point x inside the charge distribution: E(x) = \hat{x} Kx^3Then, we can calculate the total charge inside the charge distribution by integrating the charge density over the region between x=-a and x=a: Q_{total} = \int_{-a}^{a} \rho(x) dxFinally, we can use Gauss's Law to relate the electric field and charge density: E(x) = \frac{Q_{total}}{A\epsilon_0}where A is the area of the charge distribution (in this case it is 2a). We can then rearrange this equation to solve for the charge density: \rho(x) = \frac{E(x)\epsilon_0}{A} = \frac{\hat{x}Kx^3\epsilon_0}{2a}
