Electric field at the center of the equilateral triangle
To determine the electric field at the center of an equilateral triangle with a +2.0 µC charge at one vertex and two -4.0 µC charges at the other vertices, the distances from the center to each vertex must be calculated. The electric field contributions from each charge should be calculated individually, taking into account their respective distances. It is crucial to treat the electric field as a vector, resolving it into x and y components before summing them. The initial calculation provided resulted in a total electric field of 2.46 x 10^9 N/C, but the method of vector addition needs to be applied for accuracy. Properly accounting for direction is essential in vector calculations of electric fields.
mlostrac
Consider an equilateral triangle of side 15.6 cm. A
charge of +2.0 µC is placed at one vertex and
charges of –4.0 µC each are placed at the other
two, as shown in the diagram to the right.
Determine the electric field at the centre of the
triangle.
I've found the distance from each point to the centre. Now do I just find the electric field of each compared to the centre and add all three together?
That is the way.
Ok, I tried it and here's what I got:
Distance from the centre to the top vertice of the triangle (with a charge of +2.0 uC) = 8.4 cm
Distance from each of the two bottom vertices to the centre (each with a charge of -4.0 uC) = 3.2 cm
E = kQ1/r^2 + kQ2/r^2 + kQ3/r^2
= k (Q1/r^2 + Q2/r^2 + Q3/r^2)
= 9 x 10^9 ( 0.002/0.084 + 0.004/0.032 + 0.004/0.032)
= 2.46 x 10^9 N/C
Does that look like I did everything right? And, does the direction matter, or is that implied based on the negative and positive charges...
Electric field is a vector.
You cannot add up field like you add up numbers.
Draw the field vector at the center due to each of the charges. Then you'll have to resolve the fields into x & y components. You can then add up the x components & the y components.
