Electric Field of a Conducting Slab
aurora14421
A charge Q is placed at height b abouve a plane horizontal conducting slab.
Write down the electric field, E(r), at a general point r above the slab (taking the point r=0 to be the point on the slab directly beneath the charge), and show that it satisfies the appropriate boundary conditions.
Ok, I know that the electric field above a plane is sigma*r/2*epsilon_zero*r, but since this slab has a thickness where there will be no electric field, does this make a difference? Can I still use Gauss' Theorem? And what does it mean by "appropriate boundary conditions"? Just that it's continuous at the surface of the slab and zero at infinity?
Just, generally, where do I start with this question?
Thanks
For this type of problem one usually assumes that the thickness of the slap is negligible. In other words, one can consider the slab an equipotential plane.
Note that since this slab is a conductor an electric field will be induced on this plane. What can you say about this electric field?
Is this supposed to be solved by the method of image charges, or that is something completely different?
Well the charge induced at the surface of the slab will have the same magnitude as the point charge above it. But i am not sure what that tells me about the field since the geometry of the slab is different then the one of the point charge obviously
( I have problems with something very similar so thought to jump in if that's ok.. )
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
