Electric Field off the end of a Rod
To find the electric field strength at a distance x from either end of a uniformly charged rod, integration is necessary. The charge element dq can be expressed in terms of dy, using the charge per unit length. The distance r between dq and the point of interest must be defined in relation to the rod's length L and the position y. After setting up the integral with these variables, integrating over the length of the rod yields the desired electric field expression E = kQ / [x(x+L)]. This method demonstrates the application of calculus in electrostatics to derive the electric field from a continuous charge distribution.
xaer04
"A thin rod carries a total charge Q distributed uniformly over its length, L. Use integration to show that the electric field strength a distance x along the rod's direction from either end of the rod is
E=\frac{kQ}{\left[ x(x+L) \right]}."
E = \int dE = \int \frac{k dq}{r^2}
Somehow the r^2 on the bottom turns into an x(x+L) AND the dq turns into a Q. I really don't understand how they integrated this problem.
Draw yourself a diagram and define a variable that will represent the position of the charge element dq. (I'll call it "y".) Then to convert your generic expression into one specific to this problem:
(1) express dq in terms of dy (hint: what's the charge per unit length?)
(2) express the distance between dq and the point in question (hint: this will involve L, x, and y)
Once you've done that, integrate with respect to y over the length of the rod. Only then will you get the result you're looking for.
