Electric Field outside a cylinder
The discussion revolves around calculating the electric field and potential difference related to a long cylindrical wire with a given radius and electric field strength. The problem involves applying Gauss's law to determine the charge per unit length and subsequently finding the electric field at different radial distances from the wire.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the application of Gauss's law and its relation to electric flux and charge. There are questions about the correct formulas to use and the implications of integrating electric field values over specified distances. Some participants express confusion about the calculations and the validity of negative potential differences.
Participants have explored various aspects of the problem, including deriving expressions for electric field and potential difference. Some have successfully calculated values, while others are still questioning their methods and results. There is an ongoing exchange of ideas about the correct approach to integration and the interpretation of results.
There are mentions of potential errors in calculations and the importance of unit conversion. Participants are also considering the implications of their results in terms of physical meaning, particularly regarding the direction of electric fields and potential energy.
  • #31
Well, you say the sheath is a conductor.
So I would say that the field on the inside of the sheath between the inner and outer radius is negative.
Where do I go from there?
  • #32
you say the field within the material is negative ...
do you mean pointed inward?
what would happen to an electron in that material,
if there was an inward-pointing E-field?
  • #33
well e fields go from + to -, so if there was an inward pointing e field and electrons are in the material, they would be repelled?
  • #34
?? repelled ? ... from what ?
(they can't see what kind of charge is on the central wire)
do they move inward or outward?
(the Force on a qharge = qE ...)
  • #35
Sorry ...
what direction *did* E (used to) point ,
before the sheath was put there?
Where would an electron go (they move freely, in a conductor)
if it was immersed in such a 10 kV/m field ?
  • #36
Before the sheath was there, E was away from wires surface.
Hence electron would be attracted to the wire?
  • #37
yes ... (there are +++Q on the wire, that's why E points away from it)
so the electrons end up on the
inside of the sheath , or the outside of the sheath?
When do they stop accumulating there?
that is, what causes them to go there,
and what has to be =0
before they'll stop moving to the inside?
  • #38
They want to move away from the wire, but at the same time, there are electrons inside the sheath so they will end up on the outside of the sheath. meaning the charge on the inner surface of the sheath will be neutral?
  • #39
positive Qharges, the ones that are ON the inner wire,
are "trying" to get away from the other + charges on the wire,
(trying to move along E, to location of lower Potential where +q has low PE).
But these electrons are in the sheath at 2.1 mm,
and are trying to move TOWARD the ++Q on the wire,
(against E, to location of higher Potential where -q would have LOW PE).
They'll keep moving inward until:
a) there is zero TOTAL charge inside of their location
b) there is zero E-field at the place that they are at
c) the Potential is the same to their inside as to their outside.
All 3 are the same condition. Gauss relates a) to b) .
  • #40
so electrons move toward the wire. Does that make the charge on the inner surface negative?
  • #41
yes.
And you know how much neg. charge it will take (/meter length)
to offset the charge on the inner wire.
  • #42
I don't get what you mean by offset the charge on the inner wire. I just want to figure out the charge on the inner surface of the sheath..
Are they the same thing?
  • #43
Gauss says that the total E outward thru surface A
equals the total Qharge enclosed by the surface A.
for E to be 0, the total Q inside has to add up to zero.
positives and negatives offset ...
  • #44
The charge on the inner surface of the sheath offsets the charge on the wire (due to Gauss law as lightgrav explained)... so Q/x for the sheath is the negative of Q/x for the wire... From that you can get the Q/area
Or here's a different way to do it. Take a tiny cylindrical volume (or any shape doesn't matter) that goes through the inner surface of the sheath. So one end is inside the sheath and the other end is outside... Do gauss' law over that volume... The field inside the sheath is 0. The field outside, you already calculated before at 2mm. That will also give the same answer...
  • #45
I am really, really confused now!
Q/x of sheath = -Q/x for wire = -1.112*10^-12 C/m
Then I use Gauss?
But I want to find Q?:confused::confused::confused:
  • #46
Then I use Gauss?
Total Q? Are you sure they aren't asking for charge per unit length or charge per unit area?
  • #47
the exact question..
"A hollow cylindrical metal sheath with inner radius 2mm is now placed around the wire, to form a coaxial cable. What will be the charge on the inner surface of this sheath?"
I'm not sure if they are after a qualitative or quantitative answer, how do you interpret the question?
  • #48
so the rest of the electrons are not attracted toward the inside.
Q/x is as good as you can do.
(unless you want to find the charge per Area...)
Gauss is not a new foundation equation,
it deals with the same info as Coulomb's law,
so in situations like this one (symmetry!)
you often don't actually have to COMPUTE a new result.
it is sort of like weighing a mass on a spring using Newton's 3rd law;
once you know the Force by the spring, the Force by gravity is obvious.
  • #49
If they gave the length of the cylinder (or the initial wire) then you could give a total Q... I assumed that it was an infinitely long wire and cylinder... in which case charge per unit length, or charge per unit area is the only type of answer you can give.
  • #50
Yeah in the initial question the wire is described as "very long", however the question states nothing about area or length. :confused:
  • #51
Due to the wire being "very long" you can ignore the length component.
Refer to prescribed text, “Understanding Physics” Page 702.
