Electric field strength of 4 charges positioned in a square shape
The discussion revolves around calculating the electric field and total electrostatic force on a charge located at a corner of a square formed by four charged particles. The first part requires determining the electric field strength and direction at the charge's location, while the second part focuses on calculating the force exerted on that charge using the relationship between electric field and force. Participants express confusion about solving the second part of the problem but emphasize the importance of understanding the vector nature of electric fields. Ultimately, one participant successfully resolves the first question, indicating progress in the problem-solving process. The conversation highlights the interconnectedness of electric field strength and force in electrostatics.
need_aca_help
Four charged particles are at the corners of a square of side a as shown in the figure below. (Let
A = 3, B = 5 and C = 6.)
(a) Determine the electric field at the location of charge q. (Use the following as necessary: q, a, and ke.)
(b) Determine the total electrostatic force exerted on q. (Use the following as necessary: q, a, and ke.)
F=Eq
Assuming that I have to solve this algebraically...
Yeah - all they want is the resulting equation.
You also need the equation for E. Don't forget E is a vector.
I really have no idea how to solve this question...
You know how to work out the force on the charge q?
I have managed to do the first question.
Not sure how to do the second one...
The first one asks for the electric field - which you should have as a strength and direction.
The second one asks you to find the force as a result - what is the relationship between electric field and the force on a charge?
Hint: you gave the equation in post #1.
God thinking too hard on a one question resulted in tunnel vision.
Problem solved. Thank you.
No worries.
