Electric flux through a surface
The discussion revolves around calculating electric flux through a surface using the formula EAcosθ, where E is the electric field strength, A is the area, and θ is the angle. The initial calculation yielded an incorrect result of 0.167 N.m²/C due to a misunderstanding of the calculator's mode, which was set to radians instead of degrees. After correcting the mode, the correct calculation should yield approximately 0.3605 N.m²/C. Participants emphasized the importance of ensuring the calculator is in the right mode for accurate results. The thread concludes with the user expressing gratitude for identifying the error.
haha1234
Find the electric flux through the plane surface shown in the figure below if θ = 64.2°, E = 375 N/C, and d = 4.70 cm. The electric field is uniform over the entire area of the surface.
By using the equation:EAcosθ
375x0.0472cos64.2=0.167
I've found that answer is 0.167N.m2/C,but it is not correct.
What is the correct answer?
Please show us exactly how you calculated your answer.
I'v edited the content of my thread.Tell me of there are any things are need to be added.
You have done the calculations incorrectly, what did you input in your calculator?
I don't seem to be getting 0.167 with Wolfram Alpha.
Likes 1 person
But I cannot get he other answer.:cry:
E=375
d2 = .002209
Cos64.2° = .435231
Multiply the three quantities and you should get something like .3605
Likes 1 person
because the tool is interpreting the angle 64.2 in radians .
Tanya Sharma said:
E=375
d2 = .002209
Cos64.2° = .435231
Thanks. I finally found that I have changed the mode of my calculator into radian,so I cannot find the correct answer.
