How do I go about finding the ratio of the electric force?
To find the ratio of the electric force acting on an electron due to the nucleus compared to the force acting on the nucleus due to the electron, use Coulomb's law, F = K(q1q2)/r^2. The discussion highlights that the forces are equal in magnitude but opposite in direction, similar to gravitational forces between Earth and the moon. To calculate the forces, one must assume values for charge (q) and distance (r) if not provided. The ratio can be simplified to 1:1, as the forces are equal. Understanding these principles is crucial for solving the problem effectively.
atomant
Some help with this question would be much appreciated. A helium atom has a positively charged nucleus (qnucleus = +2e) with two negatively charged electrons (q = -e) orbiting it. What is the ratio of the electric force acting on one of the electrons due to the nucleus to the force acting on the nucleus due to one of the electrons?
How do I go about finding the ratio of the electric force?.
What is the formula for electric force.
Then try F(n -> e) / F(e -> n).
It's a bit like asking what is the force with which the Earth acts on the moon (or satellite) compared to the moon (or satellite) acting on the earth.
Coulombs law.
Use coulombs law to calculate the forces, then divide the force on the electron by the force on the nucleus.
Regards,
Sam
So I use F=Kq1q2/r^2. O.k, but hiw do I solve the equations when the values for q or r is not given?. I there something we have to assume in terms of calculation in order to solve this?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
