Mastering Coulomb's Law: Troubleshooting Sign and Distance Issues
The discussion focuses on troubleshooting sign and distance issues in applying Coulomb's Law to a physics problem involving two charges. The main equation used is F = k * |q1| * |q2| / r^2, where participants clarify how to handle the signs of the charges and the distances involved. A user initially struggles with equating forces and understanding the implications of distance on the net force. After some guidance, they successfully derive the correct position for a unit positive charge, concluding with a calculated distance of 29.142 cm. The thread emphasizes the importance of correctly applying signs and distances in Coulomb's Law calculations.
luap12
1. Homework Statement [http://img44.imageshack.us/img44/1104/58339946.jpg ][/URL]
2. Homework Equations [F=k*abs(q1)*abs(q2)/r^2]
3. I understand the equation, but I am having trouble with my signs and also how to include the distance in the equation. I know that the force can't be zero between the charges, and I think it has to be farthest away from the larger positive charge to make them equal to zero. The forces point in the same direction because they are opposite.]
Consider a point at a distance x from -q toward right, and find the forces on a unit positive charge due to two charges. Equate them to get the value of x.
I don't understand what you mean by that... I think I'm over-thinking this.
Force on unit positive charge due to -q at a distance x*1o^-2 m from it is...?
Force on unit positive charge due to 2q at a distance (10 + x)*10^-2 m is...?
Since net force is zero, equate them to find x.
Thanks very much, I got it now.
((k*q)/x^2)-((k*2q)/(x+10)^2)=0, solving for x gives 24.142cm. Accounting for the distance of 5cm on the x-axis give the point to be 29.142cm. This was the correct answer. Thanks!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
