Electric Potential at Point D in a Rectangle with Three Charges
To find the electric potential at point D in the rectangle with charges A, B, and C, the individual potentials from each charge need to be calculated and then summed. The formula used is VEL = (k)(q1)/d, where k is the electrostatic constant, q1 is the charge, and d is the distance from the charge to point D. The discussion emphasizes the importance of adding the contributions from each charge to determine the total potential at point D. Participants express gratitude for clarification on the method. The solution involves straightforward application of the formula to each charge.
Swan
The diagram shows three charges, A (+5.0 μC),B (-7.0 μC), and C (+2.0 μC), placed at three corners of a rectangle. Point D is the fourth corner. What is the electric potential at point D?
VEL = \frac{(k)(q<sub>1</sub>)}{d}
I don't know how to find it at Point D.
Hi Swan! :smile:
Just add the individual potentials. :wink:
tiny-tim said:
Hi Swan! :smile:
Ok, Thank you tiny-tim. :)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
