How Do You Calculate Electric Potential at Point P from a Uniformly Charged Rod?
To calculate the electric potential at point P from a uniformly charged rod, start by determining the potential contribution from each infinitesimal segment of the rod, denoted as dL. The expression for the potential due to dL involves the linear charge density (lambda) and the distance from the segment to point P. Integrate these contributions along the length of the rod to find the total electric potential at point P. Utilizing calculus is essential for summing the contributions effectively. This method provides a systematic approach to solving the problem.
Adn4n
The thin, uniformly charged rod shown in the figure has a linear charge density . Find an expression for the electric potential at P. (Use k_e for ke, lambda for , a, b, and L as necessary.)
I'm not sure how to tackle this problem, if anyone could come up with the expression so that I have an answer to work towards to, it'd be greatly appreciated.
Do you know calculus?
Find an expression for the potential caused by each "infinitesimal" length dL, and then sum them with an integral.
- Warren
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
