Electromotive Force Homework: Vertical Conducting Rods & Uniform Magnetic Field
intervoxel
Two vertical conducting rods separated by a distance d are connected to a capacitor of capacitance C. Another horizontal conducting rod of mass m is released at position y=y0 at time t=0 always in contact with the two vertical ones. The set is immersed in a uniform magnetic field B perpendicular to both rods.
a) Calculate the acceleration; the velocity and the distance delta y at time t.
b) What is the induced current?
c) Analyse the balance of energy of the system.
- standard electromagnetism formulas
a)
- calculate the emf:
<br /> \varepsilon=\oint f_s \cdot dl <br />
<br /> F_s=q(v\times B)<br />
<br /> f_s=v\times B<br />
<br /> \varepsilon=vBd <br />
<br /> \varepsilon=V <br />
Is the signal correct?
- calculate the acceleration:
<br /> a=g - F_M/m=g-[q(v\times B)]/m <br />
Here I'm stuck: How can I get rid of q?
<br /> v=\int_0^t a dt <br />
<br /> y=y_0+vt+(1/2)at^2 <br />
b)
<br /> I=dq/dt=CdV/dt=C\frac{d}{dt}(vBd)=CBd\frac{dv}{dt}=CBda<br />
c)
- formulate energy balance:
<br /> mgy=(1/2)mv^2+(1/2)CV^2 <br />
intervoxel said:
a)
Signal?
If you're asking about \varepsilon = vBd, sure, that looks right. I would have used \varepsilon = -\frac{\mathrm{d}\Phi_B}{\mathrm{d}t} to get it, but the answer is the same either way.
Try \vec{F}_M = I\vec{L}\times\vec{B} instead... at least, that's all I can think of. If that's what they're after, it seems a little strange that the problem asks you to calculate acceleration before induced current, unless they want you to leave a in terms of I.
Oh, I see. More generally
<br /> \overrightarrow{F}=I\oint_C \overrightarrow{dl}\times \overrightarrow{B}<br />
Thank you.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
