lord_blurg
- 10
Basically, I am writing up a practical experiment dealing with Electrons in a uniform electric field (I.e. Using an electron gun).
There are two parallel plates, one with a positive charge and one with a negative charge. Between these to plates is a grid which allows for easy graphing.
It can be assumed that the electric field between the plates is uniform. A grid (with lines separated by 1 cm) is shown. I need to use this information to determine the distance, d, between the plates and to calculate the strength of the uniform electric field, E.
How do I find out the distance between the 2 parallel plates? (Probably simplistic, it's just that I am doing this experiment based on an experiment video I watched)
The anode voltage is set to 3,000 volts.
The graph I got was y=(.0504)(x)^1.763
I am assuming this equation is related...
E = V/d (V is the potential difference between the plates.)
