Electrostatic force between to spheres
The discussion revolves around the electrostatic force between two solid half-charged spheres, specifically comparing the net force in two different arrangements. Participants are exploring the implications of distance and charge distribution in a three-dimensional context.
  • Participants are questioning how the arrangement of the spheres affects the electrostatic force, particularly in three dimensions. Some are considering the Coulomb force law and its dependence on distance and charge, while others are attempting to visualize the electric field of a half-sphere.
The discussion is active, with participants sharing different perspectives on the problem. Some have offered insights about the relationship between distance and force, while others express uncertainty about the charge distribution and its impact on the net force.
There is mention of a textbook argument suggesting that the net force remains the same, which some participants are questioning. The complexity of visualizing the electric field in three dimensions is also noted as a challenge.
oronanschel
given to solid half charged sphere Insulators.
In which state the mutual net force is bigger: A/B/the same
No idea how to attempt it?
The force depends on two things. Look at the Coulomb force law formula to see what they are. You will find that one of them is the same for both arrangements, but the other is different. With some thought you can approximate that quantity for each situation and then the formula will tell you which results in the larger force.
if it was 2d then it an obv that B (because distance is shorter)
but i can't get a grasp of it 3d and could't compute either.
i tried to think what is the shape of the field of half sphere but
couldn't do it either.
the weird thing is that, the book argue that the net force is the same
and i think it is not
Going from A to B, you have flipped the large half-sphere so its center of charge is closer to the center of the smaller half-sphere. That will increase the force. Yes, it is difficult to figure out exactly where the center of charge is, but certainly it is in the interior of the hemisphere. That alone is sufficient to prove smaller distance for B, isn't it?
9K
  • · Replies 18 ·
