Does Electromotive Force Have a Direction?
  • Thread starter Thread starter shalikadm
    Direction Emf
shalikadm
is the a direction in emf ??
Does electromotive force have a direction?
In some circuits it is showed as in the image above..
Please tell me that it having a direction
Yeah sure it is opposite of the integral over the electric field.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
