Energy and momentum conservation
The discussion revolves around a physics problem involving energy and momentum conservation. It specifically examines the scenario of a soldier on skis firing a bullet horizontally and seeks to determine the distance the soldier will slide before coming to a stop, given certain parameters such as mass and coefficient of friction.
  • The original poster attempts to apply conservation of momentum to find the initial speed of the soldier after firing the bullet and then uses energy considerations to calculate the stopping distance. Some participants question the correctness of the calculations and suggest there may be an error in the approach or assumptions made.
The discussion is ongoing, with some participants expressing uncertainty about the original poster's calculations. There is a suggestion that a typo might be involved, and participants are exploring the potential sources of error without reaching a consensus.
Participants are considering the implications of the coefficient of friction and the mass values provided in the problem. There is an acknowledgment of the need to verify the calculations against the stated parameters.
domagoj412
One more problem to solve...
A soldier on skis fires a bullet from rifle horizontally. After what distance will soldier stop moving if coefficient of friction between surface of skis and snow is 0,01. Mass of bullet is 0,01 kg, initial speed of fired bullet is 900 m/s and mass of soldier, rifle and skis is 60 kg?
Correct solution is: s=2,9 cm
With momentum conservation I have calculated initial horizontal speed of soldier:
m1*v1=m2*v2
60*v1=0,01*900
v1=0,15 m/s
Kinetic energy is wasted on friction:
Ek=W
Ek=F*s
1/2*mv^2=m*g*u*s (u is friction coef.)
s=11,47 cm
which is incorrect. Why?
Your solution looks OK to me.
But something has to be wrong :mad:
A typo, perhaps? What book are you using?
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 31 ·
