How to Find the Angle of a Child on a Swing at Maximum Height
  • Thread starter Thread starter again
    Energy Swing
To find the angle of a child on a swing at maximum height, the scenario involves a swing with ropes of length 2.5 m and a velocity of 0.7 m/s at the lowest point. The relevant equation derived from energy conservation is 1/2Vi^2 = gh, which allows for the calculation of maximum height, determined to be 0.025 m. The discussion suggests using a free-body diagram to further analyze the forces at play and determine the angle between the ropes and the vertical. Additional guidance is requested to proceed with the solution.
again
1. Child on a Swing
This child involves a child swinging on a swing supported by ropes of length 2.5 m. The child's velocity at the bottom of his arc is given as .7 m/s. The goal of the problem is to find the angle between the ropes and the vertical when the child is at his maximum height.
1/2mVi^2 = mgh
divide through by m ---> 1/2Vi^2 = gh
In solving this problem, I was able to find the child's maximum height using the above equation. This I found to be .025 m, however, beyond this point I am at a loss for what to do.
Any help would be greatly appreciated!
try to draw a free-body diagram .. and go on from there ..
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
