Find magnitude and direction angles of force F2 given resultant
  • Thread starter Thread starter physico
    Homework
4 replies · 3K views
physico
okay I am sure this will be easy for many of you, this is a first year engineering course question. help appreciated its due tom orow:O
* the two forces, f1 and f2 acting at a have a resultant force of fr = {100k} lb. Determine the magnitude and coordinate direction angles of the force f2 and indicate them on the figure.
ill attach the problem picture
oh yeah. i forgot to mention i don't need the answer or any drawings i just need the formula to go about it as in the the three different forces calulated with the sohcahtoa methd. I am justa bit confused about the angles
I think you need a better picture, as you don't indicate the direction of Fr and are you sure about the 100,000 resultant force? F1 is only 60.
Your drawing is not clear. Could you but some labels on it as to the meaning of each vector. Also be sure that you are representing your angles correctly. I do not understand the angle you have labeled 30D.
the 30D is the angle given for a random line so that mens this line is making an angle of 30 degrees with the negative x-axis and F1 is making an angle of 50 degrees with this line.. can u do it now please?
