How Can I Download Structural Steel Data for Temperature Ranges?
Engineering material data for structural steel across a temperature range of 20°C to 1600°C is sought, specifically regarding properties like Poisson's ratio, Young's modulus, density, thermal expansion, specific heat, and thermal conductivity. While Matweb is suggested for basic research, comprehensive resources such as specialized books on high-temperature properties of steels are recommended. The inquiry stems from a need to model the liquidus phase in weld simulations. The discussion also touches on the importance of understanding phase transitions and heat treatments, which significantly affect mechanical properties. Additionally, assistance is requested for plotting graphs in Workbench related to displacement and temperature distribution.
tomek
Hi,
from where can I download engineering material data for structural steel in range of temperature 20 deg C - 1600 deg C ( 68 F - 2912 F). I'm interested in Poission ratio, Young modulus, density, thermal coefficient of expansion, specific heat and thermal conductivity versus temperature.
Matweb is useful for some basic research, but for a more thorough resource I would recommend looking into a book covering high-temperature properties of steels.
Curious, why do you want properties of structural steel up to above the melting point of most steels, and well above the solidus transition I'm not familiar with phase transition in structural steel particularly, but I do know that you have to keep phase transitions in mind because they can drastically alter the mechanical properties. Additionally, you have different heat treatments that you have to consider if you are going to be varying the temperature between room temp and super high temps like that.
In other words, why are you asking for this information?
I want that range because curentlly make weld simulation in workbench. Steel has two phase solidus and liquidus. So I want to modeling liquidus phase trought material properties. Thank for help.
Btw. Do you know how to plot a graph in Wokrbench e.g.displacement vs X,Y or Z-Axis? Or temperature distribution between two nodes?
Thank.
With there be any change in the thermal and structural property of steel with respect to temperature. If so can anyone help me to get a lead to those data.
Kurian
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
