How does temperature affect the length of a steel measuring tape?
In summary, the conversation discusses a steel measuring tape with a known length at 70°F and a coefficient of linear expansion of 5.833 x 10-6 per °F. The question is what reading corresponds to a distance of 90000 ft when the temperature of the tape is 10°F. The solution involves calculating the length of the tape at 10°F and using it to determine the reading at 90,000 feet.
Joe_1234
25
Please help me
A certain steel tape is known to be 100000 feet long when the temperature of 70°F . When the tape is at a temperature of 10°F, what reading corresponds to a distance of 90000 ft? Coefficient of linear expansion of the tape is 5.833 x 10-6 per °F.
Mathematics news on Phys.org
My first thought was "what in the world is a "reading"? Finally I realized- this is NOT just a "steel tape" but a steel measuring tape! Let "x" be the length of the tape at 10 degrees F. When the temperature increases from 10 degrees F to 70 degrees F, an increase of 60 degrees F, the tape will have increased by a factor of 1+ 5.833 x 10^(-6) x 60= 1+ 349.98 X 10^(-6)= 1+ 3.4998 x 10^(-4)= 1.00034998. Since the length after the expansion is 100,000 feet, we must have 1.00034998x= 100,000. So the length of the tape at 10 degrees F is x= 100000/1.0034998= 99651.24058. The reading, at 90,000 feet, at 10 degrees F is given by [tex]\frac{y}{90000}= \frac{100000}{99651.24058}[/tex]. y= 10(99651.24058)/9= 110723.6 feet.
1. What are engineering materials?
Engineering materials are substances that are used to create products or structures. These materials are carefully selected based on their properties and characteristics to meet specific engineering requirements.
2. What are the different types of engineering materials?
There are several types of engineering materials, including metals, polymers, ceramics, composites, and semiconductors. Each type has unique properties that make them suitable for different applications.
3. How are engineering materials tested?
Engineering materials are tested through various methods, including tensile testing, hardness testing, impact testing, and fatigue testing. These tests help determine the strength, durability, and other properties of the materials.
4. What factors are considered when selecting engineering materials?
When selecting engineering materials, factors such as strength, stiffness, weight, corrosion resistance, cost, and availability are taken into consideration. The specific requirements of the project or product also play a significant role in the material selection process.
5. How are engineering materials used in different industries?
Engineering materials are used in a wide range of industries, including aerospace, automotive, construction, electronics, and healthcare. They are essential for creating various products such as buildings, vehicles, medical devices, and electronic components.
