kandelabr
- 110
There are two insulated air containers, first with a volume V1 and second with V2. In the first there is a pressure p1 and in the second p2. The temperatures are the same in both, thus T. Then both containers are connected with a hose so that pressure equalizes, but no heat is transferred between them.
What are the final temperatures and final pressure?
2. Homework Equations
If there was heat transfer between containers, the final temperature would be the same in both and even the same as the temperature T in the beginning and because of that I could calculate the final pressure using pV = mRT (R = gas constant for air), where I'd get mass for one container from specific volumes.
But this case with no heat transfer is a bit confusing. I can't get final pressure with the equation used above because I don't know the final temperatures. The book says the final pressure is the same as above, but I don't know why is it so.
