Equations that describe ideal gas processes
  • Context: High School
  • Thread starter Thread starter physea
    Gas Ideal gas
6 replies · 2K views
physea
Hello!
Is there a table to show the equations that describe ideal gas processes?
For example, I know for isothermic, it's P1V1=P2V2, what about the others?
Also, how are these derived? Is it from Q-W=dU? or PV=nRT?
Any help?
thanks!
Check out:
https://en.wikibooks.org/wiki/Physical_Chemistry/Thermodynamic_Processes_for_an_Ideal_Gas
https://chem.libretexts.org/Core/Ph...rmodynamics/Ideal_Systems/Ideal_Gas_Processes
It depends. Sometimes one, sometimes the other, sometimes both. For instance, can you see how you get the isothermal equation you stated?
physea said:
Hello!
Any help?
thanks!
This is a bit puzzling.
The ideal gas law equation is
pV = nRT
or
pV = NkT
Those two are the same thing and can be derived from one another.
Everything else, depending on what is kept constant, are written using that equation. For example, for isothermic reaction that you described, T is a constant, so the equation can be written as
pV = nRT = constant
meaning that the produce of p and V are constant throughout the change, i.e. p1V1 = p2V2.
For isobaric process, you have constant p, so rewriting it, you get
V/T = nR/p = constant.
This time, V and T are constants, so V1/T1 = V2/T2.
And so on. These are NOT separate equations because they are all derived from the "mother" equation, which is the ideal gas law. Asking for a table of such equations means that you do not understand that they are all from the same equation, not to mention, it may mean that you are memorizing many different forms of the same equation unnecessarily.
Zz.
pV = nRT
or
pV = NkT
pV = nRT = constant
Zz.
In addition to the ideal gas law, another equation that characterizes ideal gas behavior is dU=mCvdT
