Equivalent resistance between a and b -- Complex circuit
The discussion revolves around calculating the equivalent resistance in a complex circuit involving a 10-ohm resistor and a parallel wire. Participants emphasize the importance of recognizing that a wire in parallel with a resistor effectively creates a short circuit, rendering the resistor negligible in calculations. The concept of short circuits is clarified, explaining that they allow current to bypass resistive components, leading to an equivalent resistance of zero. Users are encouraged to simplify their calculations by ignoring short-circuited resistors. Overall, the conversation highlights the significance of accurately interpreting circuit diagrams for proper resistance calculations.
kamhogo
Req = [ ( 1 / R1) + ( 1 / R2) +. ...]^-1 (Parallel)
Req = R1 + R2 +. . . (Series )
I tried to simplify the circuit by spreading it out but I guess something is wrong with my simplification since I can't arrive at the correct answer (7 ohms)...Can someone please point me in the right direction?h
You're taking the right approach, you just made a mistake. Look at the 10 Ohm resistor in the original drawing and in your first re-drawing. It is not just in series with the last 3 Ohm resistor, there is an extra connection that you left out of your re-drawing. Try doing the simplification again.
Is this better? My answer is still a little off though...
In the original image you can see there is a piece of wire parallel to the 10 ohm resistor ... :wideeyed:
Should I add a "dummy" 0 ohm resistor on that piece of wire...? Would it change anything?
The 0Ω is across the 10Ω, a parallel resistance of 0Ω.
But then I'd have to compute [(1/0)+(1/10) ]^-1...and 1/0 is undefined...or do I just leave it out of the calculation?
I see.
It's 0/0 that is undefined; 1/0 is very large, infinity.
How about just thinking about it: what would a resistance meter measure if you had it connected to a 10Ω resistor and then you held a piece of thick wire across the resistor?
NascentOxygen said:
I see.
It would read 10 ohms...
It would read 0Ω, the wire is a short circuit.
If you had trouble using 0 in your computations, try instead a very small resistance, say 0.00001Ω and see where the calculations are heading...
Please tell me more about short circuits. I haven't learned that yet...
A short circuit is a piece of wire (a perfect conductor, ideally) that joins one node to another and causes all points along it to have the same voltage.
Ooooh. So the ideal 0 ohm wire would kind of force the 10 ohm resistor to be null? How does that work?
0 ohm in parallel with 10 ohm gives an equivalent resistance of 0 ohm between the two points.
I just tried the computation with 0.0001 ohm resistor in parallel with a 10 ohm resistor and I got 0. Wow! How can that be possible? Does it mean that the 10 ohms resistor might as well not be there?
Thanks everyone for your mentoring! Appreciated from the bottom of my heart!
Yes.
If you were an electron in a circuit and were given the choice, would you prefer to fight your way through a 10Ω resistance, or glide almost effortlessly along a copper conductor?
Yes. In future you can just recognise it, and just forget any resistor in a position that is short-circuited like that, eliminate it and not include it in your calculation.
Likes kamhogo
Second option! Thanks a lot for the image.
