What Is the Equivalent Resistance Between Points A and B?
wr1015
Find the equivalent resistance between points A and B for the group of resistors shown in Figure 21-29, where R1 = 93 and R2 = 40 .
http://server5.ihostphotos.com/show.php?id=fW6dc414515Bf2aS6b42f0eGf8aad2e7
ok i know that R_{1} and 35\Omega are in series and R_{2} is in parallel to the top 2 resistors but I am obviously making errors either in how i set up the problem or in my calculations. I have tried (1/R_{2}) + (1/2R) = 3/2R (as shown in my book) and then invert to show 2/3(R) and the answer I'm getting is wrong.. please help :confused:
You should first combine the two resistors in series, and then combine the result with the other resistor in parallel. What are the laws of combination for resistors in series? What about parallel?
for series: R_{eq} = R_{1}+R_{2}+R_{3}...
for parallel: 1/R_{eq}= 1/R_{1}+1/R_{2}+1/R_{3}...
so you're saying: 93\Omega+35\Omega+(1/40\Omega) OR (1/93 +35) + (1/40) ?
nevermind I'm an idiot.. i was forgetting to take the inverse of the answer :redface: :redface: :redface: :redface: :redface: :redface:
Clearly the first statement can't be right since you're adding things that have different units. The second looks ok as long as you mean 1/(93+35). Like I said, first combine the two resistors in series. Take that result and combine it with the other resistor in parallel.
thanks for the help
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
