Estimate the velocity and angular velocity of an empty pipe
To estimate the velocity and angular velocity of an empty pipe on a slope on Uranus, an energy balance approach is recommended, where potential energy (PE) converts into kinetic energy (KE). The potential energy can be calculated using the formula PE = mgh, with the height derived from the slope's angle and path length. The moment of inertia (MoI) losses should be considered, as they affect the kinetic energy and can be treated similarly to friction losses. Once the final velocity (Vfinal) is determined, the angular velocity (omega) can be calculated using the pipe's diameter. Additionally, a humorous note suggests that since Uranus is gaseous, the problem may not require a practical solution.
Calum Mulryan
Hi, I need to resit some exams and I'v been having difficulty trying to solve this problem.
Estimate the velocity and angular velocity of an empty pipe of mass (m)=1000kg, Diameter (d)=10mm, shell thickness (h)=1mm at the bottom of a slope of angle \theta=45^{}o and path length L=5000mm on the planet uranus (g=8.9 m/s^{}-2)
thanks
Calum
firstly, i have no interest in doing the problem for you (don't think you'll learn - i had to learn that the hard way); however, i have a high interest that you do well in your exam.
perhaps this may help:
use an energy balance: all potential energy is converted into kinetic energy
use trig knowing the hypotenuse is 5000m, and theta is 45*. easy to find the height.
you know the mass, and g. PE=mgh
shell thickness is to account for moment of inertia losses. unfortunately I am at a loss (in the 1 minute while i type this, and i don't have a dynamics book at my desk). something like I*(ang vel)^2, though
that equals 1/2 m Vfinal^2
so we have PE - MoI losses = KE
the MoI losses will act like a friction loss for the most part where they are summed along the length of the path (i.e. retarding force* distance it acts along)
from Vfinal, knowing diameter, you can find omega without too much difficulty
sorry i can't help too much on the MoI stuff, my book is 60 miles away. perhaps tomorrow if you are still stuck, i'll come back. or another member can contribute
or tell your professor that Uranus is gaseous, and therefore has no surface in which to support the ramp, so for practical purposes the problem does not require a solution
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
