Examination project of EEG, Opinions and feedback
The discussion revolves around a high school examination project focused on brain signal processing using EEG technology. The project aims to create a predictive algorithm that analyzes EEG data to suggest stimuli, such as music, to influence the user's state of mind. Participants provide feedback and raise questions regarding the methodology and challenges associated with EEG data collection and analysis.
  • One participant describes their project involving EEG data collection over eight weeks and the goal of predicting mental states based on this data.
  • Another participant inquires about how movement artifacts were managed during EEG data acquisition.
  • A participant discusses the challenges of artifact handling and experimental control, suggesting that while exact control may not be possible, average modes could still be extracted over time.
  • Concerns are raised regarding the limitations of using a ground electrode, emphasizing that it does not eliminate artifacts and that various external factors can contaminate EEG signals.
  • Methods for cleaning EEG signals from atypical components are mentioned, including frequency filtering and independent component analysis.
  • A participant offers resources for further research on music psychology, suggesting potential contacts for collaboration.
Participants express a mix of support for the project and concerns about the methodology, particularly regarding artifact management and experimental control. No consensus is reached on the effectiveness of the proposed methods or the implications of potential artifacts.
Participants highlight the complexity of EEG signal interpretation and the influence of various uncontrollable factors on the data collected. Limitations in experimental control and the need for theoretical justification regarding the effects being studied are noted.
Farhad-.-
Hello!
I don't really know how High School ends in other countries but in Sweden it ends with an examination project depending on the programme you've selected. Anyhow we were free to choose one research topic that is related to mathematics, physics, biology and chemistry. I choose the brain and is tied to physics/Biology.
I already bought a EEG equipment, Neurosky Mindwave mobile +. I already have the data for 8 weeks, 8 hours daily. Examination projects name is "Brain signal processing and algorithmic predictive model and applications", what I am basically doing is create a Predictive algorithm that records a users data for a few days and predicts the users state of mind without the EEG equipment and proceed to suggest different stimulus like music or coffee. There will be a testing phase where the user chooses a few different songs and record the affect of it. The predictive algorithm will notify the user to listen to a certain music to stabilize the mood of the user.
Here is the unfinished abstract
The brain constantly generates different kinds of signals. The signals are gathered with an Electroencephalogram (EEG), the signals can interpret the different mental states of the user. Data points was collected using OpenVibe and interpreted by MATLAB. The user had the EEG equipped during school for 8 weeks whereof the user had two instructions, one not to listen to music during school hours however only for 4 weeks. The user was also instructed to listen to music the remaining 4 weeks. Music is a stimulus and would affect the users state of mind. The second instruction was to write down the state of mind every two hours, approximately four times during school.
The reason I made this topic is to get your opinions, feedback and any sort of improvement you might have and tell me if anythings unclear.
Thanks for reading :)
Biology news on Phys.org
Fun project. :smile:
How did you deal with movement artifacts of all that movement while acquiring the EEG data?
Well the EEG machine I am using has a built in feature as in an ear clipp that acts a ground and reference, which in turn focuses on the brain.
Artifact handling, and experimental control are the most difficult parts. In what you describe it sounds like exact experimental control is not possible, but perhaps you can get away with assuming that over long times, you can still extract some average modes. But i think one should probably investigate or have some theory that makes sure that the underlying effects you seek, will as per your paradigm dominate over the uncontrolled conditions.
A ground electrode does not eliminate artifacts.What EEG does is just to record differences in scalp potentials, usually between various positions(Vin+) and a reference(Vin-). The GND is usually separate from the reference unless the conicide.
These scalp potentials are contaminated from many things beyond the brain activity. For example eyeball movements (the eyeballs are dipoles that give a relatively strong DC field), EMG such as eyeblinks,mechanical movements, causes electrodes and skin to vibrate which pulls leads, swalloing, chewing, sneezing, sometimes even the electrical field of the cardica muscle can give measurable effect in EEG. This is because the electrical field of the heart and EMG are STRONG relative to the very weak fields of EEG.
surface EEG is usually the order of 0.2-200uV, EOG, EMG and ECG are usually way larger
There are various methods all from simple frequency filtering, to advanced algorithms that attempts to clean the EEG signal from atypical components, if you measure EOG and eyeblink EMG you can even do independent component analysis and mathematically separate sources.
But one way or the other you should at least be aware of this. For sure, the ground electrode on the ear does not solve the above problems. Ie. you need to be able to argue that whatever your results are, are not biased by the lack to control of conditions and artifacts.
Unless you already as part of pre-research checked this, one of the first google this for example gives this
https://www.slideshare.net/ranjithpolusani/artifacts-in-eeg-final but you can
This sounds like a fun project though. No doubt that stimulus like audio (music) affects the state of mind. I know a few researcherin Sweden that actively work on music psychology. So if you want contact with someone to assist, check this out
http://www.psyk.uu.se/research/research-groups/the-music-psychology-group/
/Fredrik
/Fredrik
Thanks, I'll certainly keep everything in mind :)
  • · Replies 76 ·
