Expanding Universe + Rotation - Lost it somewhere
In summary: The problem lies in our lack of understanding of general relativity. Without knowing the deacceleration constant 'q', we can't determine how the acceleration affects us.
Unknowing
I am quite confused... I'll state that up front to make it simple. ^_^
Here is my question, though:
Assuming that the universe at some point started from a singularity, err... or even that, assuming that the universe is expanding at a rate that has varied over time... I assume that it's implied that is is, first off... I may be wrong, but if people generally believe the universe started small, is expanding and that at some point it will contract again, there has to be some acceleration going on somewhere... Hubble's constant involves change in rate of speed of something over distance from us ... Okay, I'm lost...
But, if the galaxy is picking up speed, accelerating in a certain direction, and the Earth is rotating and revolving and all that... we're definitely not in an inertial frame. How come at some points during the day/year/etc there isn't an increased force on us in one direction over the other due to the expansion of the universe?
I'm guessing that the problem lies in my lack of complete understanding of general relativity, but ... that's my question. Where did I go wrong? :confused:
Astronomy news on Phys.org
there is NO direction vector in the expanding univerce
IT IS JUST GETTING BIGGER IN ALL DIRECTIONS , EVERYWHERE
by space streaching NOT MOVEMENT
now our galaxy has proper motion but is not moving faster as space streaches
as they are two very different things
contraction ie the big crunch is dead
there is NOT enuff MASS to cause a crunch
so we will keep moving at the same speed
as every thing else gets farther away
other then our gravity bound local group
Okay, so it's a twofold error...
1) There is no center point from which the universe is expanding. So it's not like all the galaxies are moving away like fragments, each in a linear outward direction. Or at least there's no way to determine one with all the rotating and zooming around that's going on.
2) It's an expansion at a constant velocity in whatever direction we happen to be going, so we remain in an inertial frame with regards to universal expansion. It's not like ... an explosion where things start from zero and suddenly accelerate outward...
I think I've got it. :smile:
The Earth's rotation shows up in such effects as the Coriolis force, which is very important for weather on the planet, has significant effects on navigation, and is responsible for the precession of the Focault pendulum.
See for instance (for the weather effects of the coriolis force).
http://csep10.phys.utk.edu/astr161/lect/earth/coriolis.html
The effect of the expansion of the universe depends on what you believe the value of the deacceleration constant 'q'. With the universe currently believed to be accelerating in its expansion with a q value of -0.6, GR predicts that two points 1 kilometer apart will experience a tidal acceleration of
3.12 × 10-33 m / s-2 for every km. This is totally unmeasurable. This number was calculated by Hellfire in this thread:
https://www.physicsforums.com/showpost.php?p=464262&postcount=13
which is rather technical. I'm not aware of any textbook that derives this result, but I get the same result as Hellfire does.
1. What is meant by an expanding universe?
An expanding universe refers to the idea that the space between galaxies is continuously increasing. This is due to the fact that the universe is constantly expanding, causing galaxies to move further apart from each other.
2. How is the expansion of the universe measured?
The expansion of the universe is measured using a unit called the Hubble Constant. This constant measures the rate at which galaxies are moving away from each other, and is expressed in units of kilometers per second per megaparsec.
3. How does the expansion of the universe affect the rotation of galaxies?
The expansion of the universe does not directly affect the rotation of galaxies. However, it can affect the rate at which galaxies rotate due to the increasing distance between them. This is known as the Hubble Law.
4. What is the relationship between the expanding universe and dark energy?
Dark energy is a mysterious force that is thought to be responsible for the accelerating expansion of the universe. It is believed to make up about 70% of the total energy in the universe and is thought to be the driving force behind the expansion.
5. Can galaxies be lost due to the expansion of the universe?
While the expansion of the universe does cause galaxies to move further apart, it is unlikely that galaxies will be "lost" due to this process. However, over time, the increasing distance between galaxies may make them more difficult to observe from Earth.
  • Astronomy and Astrophysics
10K
