Exponential Integral (Possibly integration by parts)
staceybiomed
Integrate the following equation for average energy from -infinity to infinity
\int(c*x^4)*(e^(-c*x^4)/KT)dx
c, K, T are constants
\int(e^(-c*x^4/KT)) = (KT/c)^(1/4)*(2\Gamma(5/4))
I tried using integration by parts \intu dv = uv - \intv du but either way i do (with u as the exponential term and dv = cx^4 dx or the other way around), i can't seem to get the answer. Can anyone help me out?
Thanks!
might want to repost this in a simpler form without all the constants and then add those back in later, also your exponents are kinda messed up I'm guessing you wanted:
<br /> \int(c*x^4)*(e^{(-c*x^4)/KT})dx<br />
subsitute t = c*x^4/KT and use the definition of the gamma function \Gamma(x) = \int t^{x-1} e^t dt
thanks - i will give this a try!
Hi all
I would like to integrate
the integrale from o to t of (1/(1-k*exp(alpha*t))) dt where alpha and k are constant. I tried integration by part but it didnt work :s. Any help is much appreciated.
S
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
