Solve for x: 2^3+2^3+2^3+2^3=2^x
In summary, the equation 2^3+2^3+2^3+2^3=2^x can be simplified by using the properties of exponents to rewrite the left side as 4*2^3. This can then be solved by setting 4 equal to 2^x and solving for x, which gives the solution x=6. Alternatively, logarithms can be used, with the use of a logarithm with base 2 simplifying the equation to x=6.
LogarithmLuke
83
Solve the following equation: 2^3+2^3+2^3+2^3=2^x[/B]
log(a)^x=x*log(a)[/B]
What i attempted was to log both sides, bring down the exponents, and summarize them. This left me with 12*log(2)=x*log(2). I then divide both sides by log(2) and get x=12, which is wrong. Please note that all of this was with logarithms with base number 10.
Hi,
Where did you get your relevant equation ? It's dead (*) wrong, but visually close to the right one: ##\log (a^x) = x \log a##.
Taking logarithms of a sum is generally a bad idea. For a product you are better off. So make a product of the lefthand side.
And look at that. Maybe you don't need to take logarithms, but you might be able to use a simpler equation about exponentiation.
PS the term "summarizing" isn't all that mathematically sound... "sum" is what you mean. But you can't do that.
(*) [edit] well, dangerous is a better expression. It raises confusion between ##(\log a)^x## and ##(\log (a^x))##
I can see no reason to use logarithms. You are just trying to find x such that [itex]2^x= 32[/itex]. That should be elementary.
I second what BvU says. If this is an exercise of the properties of exponents, you should notice that 2^3 is a repeated sum...how many times is it repeated?
Rewrite it as a coefficient times 2^3, then write your coefficient as a power of 2.
Now, you will be able to use properties of exponents to quickly solve for x.
Otherwise, just add 8+8+8+8 and do what HallsofIvy suggested.
And if you are really feeling like using logarithms ... use log base 2.
1. What is an exponent?
An exponent is a mathematical notation that represents the number of times a base number is multiplied by itself. It is written as a superscript to the right of the base number. For example, in the expression 32, 3 is the base and 2 is the exponent, indicating that 3 is multiplied by itself 2 times.
2. What is a logarithm?
A logarithm is the inverse function of an exponent. It is used to solve exponential equations and represents the power to which a base number must be raised to get a given number. For example, the logarithm base 2 of 8 is 3, because 23 = 8.
3. What is the difference between a natural logarithm and a common logarithm?
A natural logarithm, written as ln, has a base of e, which is a mathematical constant approximately equal to 2.718. A common logarithm, written as log, has a base of 10. So, ln(x) represents the power to which e must be raised to get x, while log(x) represents the power to which 10 must be raised to get x.
4. How are exponents and logarithms used in real life?
Exponents and logarithms are used in various fields such as finance, science, and engineering. In finance, they are used to calculate compound interest and growth rates. In science, they are used to model exponential growth and decay. In engineering, they are used in signal processing and circuit analysis.
5. What are some common properties of exponents and logarithms?
Some common properties of exponents and logarithms include the power rule, product rule, quotient rule, and change of base rule. The power rule states that when raising a power to another power, you multiply the exponents. The product rule states that when multiplying two numbers with the same base, you add the exponents. The quotient rule states that when dividing two numbers with the same base, you subtract the exponents. The change of base rule states that logb(x) = loga(x)/loga(b).
