Fields in Physics assignment question about electron beams in a cathoe ray tube
The discussion revolves around calculating the speed of electrons in a cathode ray tube using given data. The kinetic energy gained by the electron is calculated as E_k = -1.6 x 10^(-16) N, leading to two different speed calculations. The first method yields a speed of 1.87 x 10^7 m/s, which is confirmed as correct, while the second method produces an incorrect result due to confusion over the variables used. Clarification is provided that the charge (C) in the second equation is the charge of the electron, and the negative sign in energy does not affect the final speed calculation. The correct interpretation of the energy's polarity is emphasized, ensuring that the final speed is a positive value.
bry
Ok so we have been given a diagram of a cathoe ray tube, with relevant data on it. The second question asks to "calculate the speed of the electron, using data from the first question". I need to make sure the answer is correct as it leads into many different questions.
I am unable to attach the picture, but here are all details:
Distance between metal plates: 5cm
Length of metal plates: 10cm
Charge on upper plate: 500V
No charge on lower plate
Charge on anode: 1000V
The first question was to calculate the kinetic energy gained by an electron traveling from cathode to anode. What i calculated was:
E_k=qV=C×V
-1.6×〖10〗^(-19)×1000
E_k=-1.6×〖10〗^(-16) N
I used two different methods to work this out, but got two different answers:
F=E_k
E_k=1/2 mv^2
v=√((2×E_k)/m)
v=√((2×-1.6×〖10〗^(-16))/(9.11×〖10〗^(-31) ))
v=-1.87 〖ms〗^(-1)
OR
s=((2×C×V))/m
s=((2×-1.6×〖10〗^(-16)×500))/(9.11×〖10〗^(-31) )
s= -1.76 〖ms〗^(-48)
Welcome to PF!
The first speed calc is correct except it works out to 1.87 x 10^7 on my calculator.
I don't understand the second - what is C? I don't recognize the formula.
Thank you!
I have put it into my calculator again a few times but still getting the same answer: 1.87x10^-24 ... I put it all in separately, so work out what 2x 1.6x10^-16 then divide it...then work out the square root. would doing this alter my answer?
In the second equation the C represents the charge on the electron. I found it on a website so I'm not totally sure it is suitable for this problem.
Also what do i do about the fact that the electron has a negative charge on it? because I'm unable to square root a negative number.
There is no negative number - the energy is positive. Technically, the polarity is oriented so the V is negative, too, so the qV is positive.
v=√((2×-1.6×10^(-16))/(9.11×10^(-31) ))
Say you separate the numbers and powers: 2x1.6/9.11 = 0.35
The power of 10 is -16-(-31) = 15. So under the square root, 0.35 x 10^15
Square root of that is 1.87 x 10^7.
