Calculating Velocity of a 10kg Bicycle Down a 150m Hill
To calculate the velocity of a 10kg bicycle rolling down a 150m hill with no energy losses, the principle of energy conservation can be applied. The potential energy at the top of the hill converts entirely into kinetic energy at the bottom. The formula for potential energy is PE = mgh, where m is mass, g is the acceleration due to gravity, and h is height. The kinetic energy at the bottom is given by KE = 0.5mv². By equating the potential energy at the top to the kinetic energy at the bottom, the velocity can be determined.
tuttyfruitty
Hi, i am confused with where to start with.
A cyclist is on a bicycle with a mass of 10kg rolls down a hill 150m high. with zero losses what is the velocity of the bike at the bottom of the hill?
could some one please send me in the right direction with formulas
Zero losses -> use energy conservation?
Welcome to the PF.
Please use mfb's hint to show some effort on your question.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
