Find an expression of g(x) in terms of x for an equation f(x)?
  • Thread starter Thread starter fs93
    Expression Terms
fs93
The function f is defined by f(x) = x^3
Find an expression for g(x) in terms of x in each of the following cases.
(a) f [ g(x) ] = x+1
(b) g [ f(x) ] = x+1
I got the same answer both times. g(x) = cubic route (x+1). Because if I put the cubic route of x+1 in f(x), it is cubed, and I'm left with x+1.
For (b) its the same. If I have cubic route of (x+1), and then cube it, I'm left with x+1. Is this correct?
I'd appreciate some help :)
The first one is okay. For the second one, if g(x) = \sqrt[3]{x + 1} then g(f(x)) = \sqrt[3]{x^3 + 1} \neq x + 1.
Why don't you try g(x) = \sqrt[3]{x} + 1
Thanks, that really clears things up.
But is there a method that I can always apply to such a question?
Or do you always have to keep doing trial and logic until you find the correct function?
For the type of question you posted, it's more or less using your logic and just seeing what the correct function should be, combined with some trial and error.
That's what I'm going to practice then. Thanks a million.
For b, you want to find g so that g(x3 + 1) = x + 1, so you need to figure out what g needs to do to an input value so that the output is x + 1.
To get from x3 + 1 to x + 1, g would need to:
  1. Subtract 1 from the input value.
  2. Take the cube root (not route) of the value from step 1.
  3. Add 1 to the value from step 2.
JG89's suggestion, g(x) = \sqrt[3]{x} + 1
doesn't do the first step, just the second and third, so doesn't work as the formula for g(x).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
