Find flow given: diameter, length, pressure
The discussion revolves around calculating the flow through a pipe connecting a pump to an outlet, given parameters such as gauge pressure, pipe diameter, length, and elevation change. Participants explore various methods and equations relevant to fluid dynamics, including the Darcy-Weisbach method and Bernoulli's equation, while addressing the characteristics of different types of pumps.
  • One participant seeks guidance on finding flow with known parameters, including gauge pressure and pipe dimensions.
  • Another suggests using a specific thread and document for pipe flow analysis and offers to input known data into a program.
  • Some participants express uncertainty about the downstream pressure, with one questioning if it is known.
  • Discussion includes the type of pump being used, with distinctions made between centrifugal and positive displacement pumps affecting flow calculations.
  • One participant confirms assumptions about pressures and velocities, emphasizing conservation of mass for a positive displacement pump.
  • Another participant outlines a method for calculating flow using the Bernoulli equation and discusses the need for estimating friction coefficients.
  • There is a query regarding the interpretation of head loss in Bernoulli's equation, with participants clarifying that it encompasses both friction and elevation losses.
Participants generally agree on the importance of knowing the type of pump and its characteristics for flow calculations. However, there remain multiple competing views on the best approach to calculate flow, and the discussion includes unresolved questions about specific parameters and methods.
Participants mention various assumptions and conditions, such as the incompressibility of water and the need for specific pump curves, which may affect the calculations. The discussion reflects a range of approaches and methods without reaching a consensus on a single solution.
sphynx_000
I am trying to find the flow through a pipe between a pump and an outlet
I know
-gauge pressure just after the pump
-pipe diameter
-pipe length
-elevation change
Any idea how to go about this?
Check this thread:
https://www.physicsforums.com/showthread.php?t=211590
Open up the attached document "Pipe-Flo Pro.PDF" (post #4) for pipe flow analysis.
Or just post your known information and I'll shove it into a program.
- Pipe ID
- Pipe length
- Upstream pressure
- Fluid type
- Fluid temp at upstream pressure location
- Number of elbows or bends
- Elevation change
- Valves (need Cv)
- Either flow or downstream pressure. Can't do both.
hummm,
I don't know flow or downstream pressure,
Are you sure you don't know the downstream/exit prsesure? :wink:
You can work backwards using this:
http://www.pipeflowcalculations.com/flowrate/index.htm
What kind of pump is it? What fluid? If it's a centrif then you are in a pinch. You would need to determine the total head of the system and then use that to compare to the pumps pump curve to find out what its output flow would be.
If it is a positive displacement pump then it's pretty straight forward.
water, displacement pump...
I think i have it about figured out, I will post some results soon
Ok, now I am stumped again.
Could someone confirm this for me?
- my p1= gauge pressure after pump, and p2=0 at outlet?
- Also my v1=v2, same diameter pipe, incompressible fluid, water
I have used the Darcy–Weisbach method to calculate the friction head loss. Now I need to use Bernoulli equation to calculate the elevation head loss right?
Your assumptions are correct for the pressures and velocities.
If it is a PD pump, you have your flow. Conservation of mass means that what the pump is putting out is your flow. Since it is water and treated as incompressible, your volumetric flow rate is also constant. The only reason at this point in calculating head loss is to find out expected pressures somewhere along your pipeline.
What EXACTLY is it that you want to calculate?
maybe I am making this way to complicated.
All I readlly need to do is find the flow.,
As Fred was saying, if you know the pump and have the curves, you should be able to tell your flow by the head its producing.
These are my only knowns
-pressures
-elevations
-bends
-diameter
-length
As mentioned, it would help to know if it is a positive displacement (PD) pump (ie: such as a reciprocating piston or gear pump) or is this a centrifugal or similar style pump? For PD pumps, the flow rate is fixed regardless of pressure. For centrifugal pumps, the flow rate is a function of dP across the pump. That dP needs to be determined in order to find pump flow for a centrifugal. To determine dP, you will need to determine pressure drop through the pipe so it can be matched to the 'pump curve' for the pump you have.
Now I see exactly what you are looking at. This is referred to as a TYPE 2 problem.
First set up an equation using the energy equation (the Bernoulli equation with the added loss terms) to come up with an equation that is a function of f and V.
You'll need to guess at the friction coefficient and then calculate V and Reynolds number. Use the Reynolds number you just calculated to look up the friction coefficient in a Moody chart. If the initial guess and the looked up values are close, you are done. If they are not close, make a new estimate for f and repeat.
Ok, I think I finially starting to learn enough to solve this problem.
One more general question.
With bernoulli's equation like...
[p/y+V2/2g+z]1 - [p/y+V2/2g+z]2 = hL
The hL is the head loss due to what?
I am confused if this is due to friction, elevation, or both?
Head loss is a generic term for a drop in a fluid's pressure. Your equation above is correct, but to calculate the total head loss (total pressure drop) in a pipe, the Bernoulli equation is insufficient. Bernoulli's assumes there is no frictional losses, so the fluid per Bernoulli's would behave like a perpetual motion machine, never loosing total pressure. To fix this, the Darcy Weisbach equation is added into the Bernoulli equation as shown in the manual I posted here:
https://www.physicsforums.com/attachment.php?attachmentid=12408&d=1201620608
See page 14, equations 15 and 16.
  • · Replies 38 ·
  • · Replies 37 ·
