Find Magnetic Field from Electric Field Using Maxwell's Equations
The discussion focuses on deriving the magnetic field \(\mathbf{B}\) from the given electric field \(\mathbf{E} = E_0 \cos(kz - \omega t) \hat{x}\) using Maxwell's equations. The initial attempt resulted in an incorrect expression for \(\mathbf{B}\) due to a miscalculation during integration. The correct magnetic field is \(\mathbf{B} = \frac{kE_0}{\omega} \cos(kz - \omega t) \hat{y}\), which aligns with the expected solution. The error was identified in the integration process of the time derivative of the magnetic field.
  • Understanding of Maxwell's equations, specifically \(\mathbf{\nabla \times E} = \dot{\mathbf{B}}\)
  • Proficiency in vector calculus, particularly cross products and integrals
  • Familiarity with electromagnetic wave equations
  • Knowledge of trigonometric identities and integration techniques
  • Review the derivation of magnetic fields from electric fields using Maxwell's equations
  • Study integration techniques for trigonometric functions in the context of physics
  • Explore the implications of electromagnetic wave propagation in different media
  • Learn about the physical significance of the terms in Maxwell's equations
Students studying electromagnetism, physics educators, and anyone interested in the mathematical foundations of electromagnetic theory.
ADCooper
An electromagnetic wave has an electric field \mathbf{E} = E_0 \cos(kz-ωt) \hat{x}. Using Maxwell's equations, find the magnetic field.
\mathbf{∇\times E} = \mathbf{\dot{B}}
So this problem appears extremely simple, but other students have told me my answer is incorrect, and I can't figure out what is wrong with my math. I find the cross product, which results in the following equation for the time derivative of the magnetic field:
\mathbf{\dot{B}} = \hat{y}kE_0\sin(kz-ωt)
I now integrate both sides with respect to time. This is where my answer diverges from others, so I'll fully write out my steps:
\mathbf{B} = kE_0∫_0^t \sin(kz-ωt') dt'\hat{y}
I set u = kz-ωt', which means du = -ωdt'
Plugging this in, the new integral is:
\mathbf{B} = -\frac{kE_0}{ω}∫_{kz}^{kz-ωt}\sin(u)du
The result is then
\mathbf{B} = \frac{kE_0}{ω}[\cos(kz-ωt)-\cos(kz)]\hat{y}
However, every student I've talked to has told me that the correct answer should be
\mathbf{B} = \frac{kE_0}{ω} \cos(kz-ωt)\hat{y}
Is there something simple I'm missing? There's nothing else in the problem description I didn't write. The other answer looks more correct but I can't find any reason that mine is incorrect.
The left side of the second equation above is incorrect. Think again about what you get when you integrate the left side of the first equation from t' = 0 to t' = t.
Woops thanks for the help, figured it out!
