Find Max Speed Before String Breaks for 6 kg Rock on Rope
  • Thread starter Thread starter TheronSimon
    Rock String
To determine the maximum speed of a 6 kg rock spinning in a circle before the string breaks, the maximum tension of 75 N must be considered. The net force equation Fnet = ma is applied, along with the centripetal acceleration formula a = 4π²R/T². The calculations show that the gravitational force equals the centripetal force, leading to a tension calculation of T = 2.2 seconds for the period. The user seeks confirmation on whether to use the acceleration formula to find speed using a = v²/R. The discussion emphasizes the relationship between tension, acceleration, and speed in circular motion.
TheronSimon
so there's a 6 kg rock spinning in a circle with a string that can with stand a maximum tension of 75 and a radius of 1.5m
and i need to find the maximum speed before the string will break
Fnet=ma
a=4\pi2R/T2
so Fnet =ma and a = 4\pi2R/T2
so Fg = m*4\pi2R/T2
so 6*9.8 = 6*4\pi21.5/T2
so 58.8 = 284.24 / T2
so T = 2.2
no would i be able to use this formula a=4\pi2R/T2 to find the acceleration and then use a= v2/R to get the speed?
anyone?
no nothing?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
